My PHII head will not pump in water from the thru hull....it will pump out..
although somewhat reluctantly. The thru hull is open and does provide water to the AC system so I know the thru hull is open....there is a 'T' on the line that sends water to the head when required......It typically works fine.....could the 3/4 inch hose be plugged....perhaps the tank is nearly full..? your thorughts are appreciated Peggy.....by the way, the vent thru hull was totally plugged with bugs & debris. Patrick
