I have a 1982 , 22 feet macgregor ,
Swinging keel banging , I got the keel almost out to realize the pivot whole was used and too big for the bolt holding
I made a bushing etc..proble still persists , so we decided to add two plastic washers one on each side to help avoid Keel move lateraly , I need help for size of the washers , circle 4 inch diameter and 1/4 nch thick seems ok but how to get the washers on the bolt , between Keel and sides of Keel casing
Much more important is that problem will not be solved as long as the Keel moves like a pendulum , banging on each side of the casing at its the lower level , which is bad also for the bolt , bushing etc...at the top of keel..enlarging again the pivot whole on the keel..need ideas to add a guide , allowing the Keel to be in the middle of casing and not banging left and right sideways ( port to starboard) ..there is no access to add anything in that section of the Keel casing....can we add two peices of plastic on the Keel a few inches below bolt , so that the keel will stay straight and her path will be only front and back for lifting it .....
Thanks Iam kind of desperate , I was thinking of putting a new Keel ..but this seems like a bigger problem
Thanks
Thanks
