Planning to install LMR-400 coax in my OD34. It has the usual Isomat mast, extrusion NG51. The mast has 2 T's extruded on the inside with a plastic conduit for wiring slid over each T. One goes to the spreaders, one to the masthead. The coax will fit into the conduit with the other wires although a bit snug. Looks like getting it to the masthead will be doable but challenging. Getting it out the side of the mast at the top to attach to the antenna looks like the real issue. The coax is stiff and needs to exit much like a halyard through a halyard plate.
Removing the plate at the mast top leaves very limited access to the inside of the mast. The conduit ends only 1/2" below the very top. The coax needs to exit 6" or a foot below the top. I don't see that I can get into the mast to cut the conduit. Can you slide the conduit off the end of the T and out the top, cut it and slide it back? Anyone installed LMR or RG8 in this mast who can give me some direction?
