My exhaust exits the transom just above the boot stripe and it is pretty much submerged when running over 6 knots as the boat squats at higher speed. Prior to my engine change from 1GM to 2YM15, the exhaust was only submerged if pressed to full throttle and reaching about 6 to 6.2 knots. I would normally cruise along at a speed where the exhaust was just above water, otherwise, I noticed black soot in the water and (often) exhaust smell in the cockpit.
I always assumed that submerging the exhaust had a tendency to cause the exhaust to ride up the transom into the cockpit.
Now with the new engine and higher cruising speed, the exhaust is always submerged. I don't notice any difference or smell, but I wonder if there is a preference for exhaust to be submerged or above waterline at all times. I don't relish changing the current location.
The second question is a moot point now but I'll ask anyway. My exhaust elbow and hose used to be 1-3/4" but the opening thru the transom was restricted to about 1-1/4" at most. Bad boat design, I suppose ... but does this contribute to engine maintenance problems? What would be anticipated problems? (Now my exhaust is 2" throughout).
