Sorry for the long post: I'm hoping Maine will be able to clarify a few things.
I believe he considered the Sterling Crossover Switch (SC50) as a possible good fit for a shore power/generator/inverter supply switch. I also saw a comment Maine made in another thread about how the green and neutral wires should be connected for multiple power input sources. My confusion is that the wiring diagram from Sterling does not seem to match Maine's recommendation.
1. Attached is the wiring diagram from the Sterling spec sheet. It seems to show that the green wires from all three possible sources Shore, Generator, and Inverter are connected (un-switched) to the load side green wire going to the boat? It also appears to show the common (neutral) wire connected when the switch is in the selected position. This seems to be at odds with Maine's recommendation. Am I missing something?
2. I'm also a little confused where the new Galvanic Isolator would be wired into the circuit? Any help would be appreciated:
Quote from Maine at Compass Marine in an earlier thread:
[FONT="]Quote:[/FONT]
[FONT="]Originally Posted by Jeff Jellick [/FONT][FONT="] [/FONT][FONT="][/FONT]
[FONT="]
Yes, I have added a 3 - position selector switch, that allows me to switch between, Shore Power, Generator, or Invertor. So, to answer your question, when I am running off the Invertor, I cannot be connected to Shore Power. I added this as a safety option.[/FONT]
[FONT="]Jeff,
Be 100% sure this was done correctly, the vast majority of transfer switches I see installed are done incorrectly.
When on shore power AC NEUTRAL and GROUND ARE NOTconnected on the boat
When using INVERT AC NEUTRAL & GROUND ARE connected on the boat
[/FONT]
[FONT="]
When using GENSET AC NEUTRAL & GROUND ARE connected on the boat[/FONT]
[FONT="]
[FONT="]Jeff,
[/FONT]
[FONT="]
