I need to repair the gunwale, starboard side, just forward of the "gate" stanchion. Yesterday I was attempting to remove the stanchion. In the cabin under this stanchion is the electrical panel. It will be extremely difficult to remove the primary stanchion nut as it is.
When I looked for the nuts for the "brace" part of the stanchion (this is the circled part in the pictures), they cannot be seen. The electrical panel box completely blocks them. With that in mind I then assumed these 2 bolts must be screws. They turned, but did not unscrew. So I am back to assuming they are bolts with nuts???
Does anyone know if these are screws or bolts? If bolts, now does one access them? Cut a hole in the vertical surface near the terminal strip (see pic 4). I realize this hole would then be an avenue for water to get to electrical wiring, and would need sealing when done.
