OK.........
For folks out there using delrin for anything on your boat blocks,bases what ever
Centerline nailed it.
Used propane torch and as exactly as he stated you have to be careful not to put too much heat on it or it will bubble
What I did was to pass the torch over the delrin and get it hot on the first couple of passes. Then I took a single edge razor blade and dragged it over the surface while it was still warm. You have to be careful in this because while the del is soft the blade can dig in. So dragged it a couple of times, this leveled the surface from the cut of the band saw. And as the surface got smoother the propane torch worked progressively better. Took about 5-6 passes but now have a great finish on my bases
Need to know something just ask this site
Amazing talent hear!!!!!!!
