MMSI!!! I'm confused here, who's on first base?
Pearson P303 #221 RockPort Maine
Great find here
From boat us FAQs on MMSI.
What is the difference between obtaining an MMSI from the FCC and obtaining a number from BoatUS?
BoatUS MMSI numbers are coded for recreational vessels cruising in U.S. waters only not otherwise required to be licensed; the registrations are downloaded into the U.S. Coast Guard Search & Rescue Database (MISLE) only. FCC-assigned MMSI numbers are coded for International Waters and go into the International Search & Rescue Database (ITU). In order to be accepted into the ITU database, any FCC assigned MMSI must end in zero. This is why the BoatUS MMSI number cannot be re-used when later applying for an FCC License for international cruising.
Cool so just add a zero to your MMSI number and your good to go?
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
I'm pretty sure the VHF Distress Alarm can fire off w/o MMSI or GPS input into the unit. I periodically hear Sector Los Angeles reporting having received a distress alarm; however, "vessel description is unknown" (i.e., no MMSI) and "vessel position is unknown" (i.e., no GPS). "All mariners are requested to keep a sharp lookout...." So, w/o those two items, the DSC distress alarm is pretty much useless for rescue.
Reminds me of the many Maydays I heard around Tampa Bay. When asked for position, repondents would reply to the effect, "I am here out in the Gulf; I can see the dome" [= Devil Rays stadium dome in downtown St. Pete which can be seen 10 n.mi. out]. If a little closer, you'd hear... "I can see the Don Cesar!" [= a prominent hotel on St. Pete Beach]. Off Long Beach, it's the same response except now it's "I can see the Queen Mary!" So, pushing the DSC alarm w/o GPS is akin to calling a Mayday that says "Help! I'm out here in the ocean; I don't know where, but I can see Catalina Island!"
8,062
You don't need the FCC version for international waters per say. Who's going to enforce it. You do need it and the ship license to use your VHF at all in Canadian, Mexican, and the waters of any other nation with agreements with US.
Boy, am I in big trouble in Mexico! :D
slaume
Feb 21, 2014
105
Cape Dory 30 C Noank
I got an MMSI number from Boat US and loaded it in my Standard Horizion radio. It was quick and easy. Then I decided I needed a ships radio license because of traveling to countries that require one. I started through the licensing process and hit a huge road block when it would not accept the Boat US number. Since it is already entered into my radio and can not be changed I kind of gave up on the process. I have been to Canada before and they let the ships license slide but I would like to remedy this situation. Any thoughts on this? I ran into the same thing in Bermuda. I knew I was supposed to have the license but guessed correctly that they wouldn't just tell me to go away, Steve.
FCC Enforcement Advisory
FCC Enforcement Advisory: Marine Radio, Enforcement Bureau Reminds Boaters of Marine Radio Rules
Directs Boaters to Check Safety Communications Equipment to Ensure Compliance
As the summer boating season ramps up, boaters are urged to familiarize themselves with marine safety communication requirements, and ensure that their equipment is operating properly. The FCC regulates marine communications in cooperation with the United States Coast Guard, which monitors marine distress frequencies continuously to protect life and property.
All users of marine radio, whether voluntary or compulsory, are responsible for observing both FCC and Coast Guard requirements. Each summer, the United States Coast Guard reports a significant number of false distress calls and incidents ranging from a simple lack of courtesy to intentional interference. The Enforcement Bureau intends to strictly enforce the Rules related to marine radio operations. Ensuring the integrity of safety and distress frequencies is vital to safeguarding lives and property.
What Should You Know?
Most recreational boaters are authorized to operate VHF marine radios, radar, and emergency position-indicating radio-beacons (EPIRBs) without having to obtain individual licenses from the FCC. However, boaters must continue to follow the operating procedures for calling other stations, maintaining a safety watch, and relaying distress messages as specified in the FCC's Rules, available at http://www.gpo.gov/fdsys/pkg/CFR-2009-title47-vol5/pdf/CFR-2009-title47-vol5-part80.pdf. Depending on the type of operation, you may identify your ship station over the air using your FCC-issued call sign, maritime mobile service identity (MMSI), the state registration number or official number of your ship, or the name of your ship. To check if your vessel license information is correct, you may search the FCC database of licensed stations at http://wireless.fcc.gov/uls/index.htm?job=home.
VHF Marine Channel 16 Designated for Emergency Calls
Section 80.369 of the FCC's Rules states that VHF Marine Channel 16 (156.800 MHz) is the international voice, distress, urgency, safety, call, and reply channel for ship, public, and private coast stations. The Coast Guard continually monitors Channel 16 and treats any distress call received as an emergency that should be immediately investigated. Prohibited Channel 16 communications include:
false distress or emergency messages, superfluous communications, messages containing obscene, indecent, or profane words or meaning, general calls (calls not addressed to a particular station), routine messages and radio tests, and communications when your ship is on land (for example, while the ship is on a trailer).
Emergency Position-Indicating Radiobeacons (EPIRBs) Only Authorized for Emergency Use EPIRBs, devices that cost from $200 to about $1500, are designed to save your life if you get into trouble on the water by alerting rescue authorities and indicating your location. Section 80.1161 of the FCC's Rules requires that EPIRBs be used only under emergency conditions, while section 80.89(a) of the Rules prohibits unauthorized or superfluous
transmissions. Some EPIRBs automatically activate when wet and others are manually activated. Both types can be used when a ship is in distress by emitting a radio signal marking the ship's location for rescue responders. Boaters must exercise extreme care to prevent inadvertent activation in non-emergency situations.
Registration of EPIRBs Required
Current 406 MHz EPIRBs have a unique identifier that must be registered with the National Oceanic and Atmospheric
Administration (NOAA) whenever installed or replaced on a vessel, pursuant to section 80.1061(f) of the FCC's Rules.
(You may now register online.) Registration will help rescue forces find you faster in the event of an emergency.
Older EPIRBs operating only on 121.5 MHz/243 MHz should be replaced as they are no longer detected by satellites,
and their use is now prohibited under the FCC's Rules. For information on
recommended monthly EPIRB test procedures, see http://www.sarsat.noaa.gov/EPIRB_inspecting.pdf.
Ship Station Licenses Required for Commercial Vessels Commercial vessels that are required by statute to carry radio equipment must apply to the FCC for a ship station license.[/COLOR] The ship station license specifies the type of radio equipment that the vessel is authorized to use. All radio equipment must be properly licensed, and type accepted
for maritime use. Ship stations are specifically prohibited from employing unlicensed or unauthorized radio equipment, such as unlicensed or unauthorized amateur or aircraft transceivers.
What Happens if Users Do Not Comply with the FCC's Rules? Interference to a maritime distress and safety frequency, including VHF Marine Channel 16, is a violation of the most critical nature, with potential impact upon safety of life and property. Harmful interference can be caused not only by intentional operation, but also by stuck microphones on Channel 16, and inadvertent activation of EPIRBs. Harmful interference disrupts vital safety frequencies, and can obscure genuine distress transmissions. Tracking down such interference also places a strain on valuable resources of the safety and rescue agencies. Be aware that the Enforcement Bureau intends to strictly enforce the Rules
related to marine radio operations. 1 Violators may be subject to the penalties authorized by the Communications Act, including first offense fines as high as $16,000 for each violation or imprisonment for up to one year. Your radio equipment can also be seized and forfeited to the U.S. Government. In addition, the Coast Guard can recover the costs of its rescue efforts when the initiating distress call is determined to be false; these rescue-related costs can be as much as $5,000 per hour.
What Should You Do?
Marine safety and distress radio communications are designed to protect both your life and the lives of those around you fellow boaters, friends and loved ones. Please take the time to learn the FCC's Rules governing proper radio operation and comply with them. Common sense and simple courtesy can help keep you from harm's way. Safety equipment is there for your own benefit. Your life may depend on it.
Need more information?
To file a complaint, visit www.fcc.gov/complaints or call 1-888-CALL-FCC. For additional information regarding enforcement of the marine radio rules, visit the websites below or email MarineRadio@fcc.gov.
Media inquiries should be directed to David Fiske at (202) 418-0513 or David.Fiske@fcc.gov.
For information related to ship station licenses, proper use of marine VHF radio channels, and licensing of marine radio
stations, please visit the FCC website at http://wireless.fcc.gov/services/index.htm?job=licensing&id=ship_stations.
For more information on EPIRB registration, please visit the NOAA website at
https://beaconregistration.noaa.gov/rgdb/.
For more information on EPIRB and other Coast Guard requirements, please visit the Coast Guard website at
http://www.navcen.uscg.gov/?pageName=mtEpirb and http://www.uscg.mil/hq/cg5/cg5214/epirbs.asp.
To request materials in accessible formats for people with disabilities (Braille, large print, electronic files, audio format), send an
e-mail to fcc504@fcc.gov or call the Consumer & Governmental Affairs Bureau at 202-418-0530 (voice), (202) 418-0432 (TTY).
You may also contact the Enforcement Bureau on its TTY line at (202) 418-1148 for further information about this Enforcement
Advisory, or the FCC on its TTY line at 1-888-TELL-FCC (1-888-835-5322) for further information about the marine radio rules.
Issued by: Chief, Enforcement Bureau
1 See Vincent E. Aversa, Jr., Forfeiture Order, DA 11-549 (Enf. Bur. 2011) (assessed a $20,000 forfeiture for unauthorized
operation on Channel 16); Princess K Fishing Corporation, Forfeiture Order, 24 FCC Rcd 2606 (Enf. Bur. 2009) reconsideration
pending (assessed a $5,500 forfeiture for unauthorized activation of an EPIRB).
Feb 20, 2011
8,062
Are you sure it can't be changed?
I've heard that today's radios (at least mine) can be MMSI'd at least a couple of times, but that may be brand-specific?
Where's that user manual....
Here is a few exam questions 2015 on a test sheet of the FCC
9B5 Which of the following documents or publications are required by Part 80 of the FCC rules for vessels on international voyages (other than the Great Lakes)?
A. ITU List IV & List V, Appropriate Safety Convention Certificate & ITU manual for Maritime Mobile stations.
B. Appropriate Safety Convention Certificate, ITU Master Plan of GMDSS Coast stations, and ITU manual for
C. ITU Master Plan of GMDSS Coast stations, ITU manual for Maritime Mobile stations, ITU List IV & List V.
D. ITU List IV & List V, Appropriate Safety Convention Certificate & IMO manual for Maritime Mobile stations.
9B6 Which of the following references should be consulted to identify the name of a vessel based on its Maritime Mobile Service Identity?
A. ITU list of Coast Stations.
B. ITU List of Ship Stations and Maritime Mobile Service Identity Assignments.
C. ITU List of Radio-determination and Ship Stations.
D. ITU Master Plan of Shore-Based Facilities.
9B4 Which of the following documents or publications are required by the FCC for GMDSS vessels on international voyages (other than the Great Lakes)?
A. IMO master plan of shore-based facilities (or substitute), station logs, appropriate operator licenses, Inmarsat handbook for GMDSS.
B. NGA Pub. 117 (or substitute), station logs, appropriate operator licenses, IAMSAR manual volume III.
C. Part 80 FCC rules, station logs, station licenses, ITU publications, IMO manual for Maritime Mobile stations.
D. Part 80 FCC rules, station logs, station licenses, ITU publications, ITU manual for Maritime Mobile stations.
Answers: ITU Publications...Paper!
9B4 – D
9B5 – A
9B6 – B
I understand that they have a password to delete the MMSI number! I don't have it but, for security reasons... it's a great idea. The thefts that go around stealing radio's are S.O.L. now...LOL Don't you think? :eek:
Feb 20, 2011
8,062
I think you have to send the radio back to the manufacturer, who'll clear the MMSI.
Just kowtow and get your international MMSI and be done with it, until the next lightning strike takes out your radio completely. ;)
The thieves will just move on to dinghy motors and the like, but most of the world doesn't really care about that little distress button.
slaume
Feb 21, 2014
105
I am never too worried about theft at home or on the water, to the point that I never considered that as a reason for the radio lock. The Standard Horizon radio does need to be sent back to clear the MMSI and I don't believe you are allowed to have two numbers on one vessel but maybe that is less of a concern than not having a radio license, so I will probably proceed along those lines and send the radio back when I can. While the Boat US registration is very easy, they should include a huge caution stating that it is not valid for international purposes. I hate the paper work part of sailing. I still haven't got the documentation part of international compliance done yet either, Steve.
Feb 20, 2011
8,062
snip- I hate the paper work part of sailing. I still haven't got the documentation part of international compliance done yet either, Steve.
The "paperwork" is mostly the handing over of money.
True evidence of compliance.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Most radios can have the original MMSI number put in and changed once prior to having it sent back. Check your manuals. I can say this is true for the intrepid models of Standard Horizon.
Jul 27, 2011
5,203
That's true for the fixed mounted type; at least the older ones. The new Standard Horizon DSC/GPS hand-held (HX870) that I purchased recently allows one input only. If you goof-up the first time and insert an incorrect MMSI number it has to go to the factory to be reset.
