Paint PVC?
We've made some awning support poles from 1 1/4 inch pvc. We thought it might dress them up a bit if they were painted. Does anyone have an Rx about what paint or to paint at all?
Coyote
Sep 30, 2008
132
Hunter 30T Madeira Beach, Florida
Hey Andrew:
I have had OUTSTANDING results on assorted plastic painting projects, both around the house and on the boat (Dorade Cowl Vents) with: Krylon Fusion
recommended for PVC,,
http://www.krylon.com/products/fusion-for-plastic/
NO Primer needed, fast drying, no sanding, and Chip Resistant -
and great color assortment,,,
cheers,
Coyote
Mar 20, 2012
3,983
Make sure to use a scotchbrite pad and remove the printing on the pipe or it will bleed thru some paints, especially the red printing... the paint helps make it last longer under the uv rays also...
