Rudder cracks - '81 Cherubini Hunter 36
tmjb
Mar 13, 2012
222
Hunter 36C Glen Cove
I apologize in advance if this is a topic that has been addressed elsewhere. If so, I couldn't find it.
My boat is new to me but is an '81 Cherubini Hunter 36. It is somewhat unusual in that it has reportedly not been in the water in 17 or 18 years (last in '97).
My question relates to horizontal cracks in the surface of the rudder that you can see in the attached photos both before and after some removal of some bottom paint. They only exist on one side only. The other side looks fine. When sounding with a hammer the rudder sounds solid and uniform throughout.
Has anyone experienced/addressed this issue and/or have any advice as what best to do?
I much appreciate any input.
Many thanks in advance.
207
Hunter 40 Saint John
I have seen this type of cracking before. Unfortunatly, it was bad news, It looks like the shaft might be trying to spin internal to rudder. and some delamination has occured. In that case we had to remove the rudder and have the fibreglass redone. SOme of it may have been for piece of mind some structural. Either way, the internal 'wings' where the cracking is occuring must be putting some undue forces on the fibreglass. I would get her fixed before she seperates once she is back in the water...
braol
Apr 16, 2014
348
Hunter 27 Rebel 16 Great Lakes Naval Base, IL
You could always go the "inject and fill" route with epoxy. I did that on my rudder, first with unthickened epoxy and then some thicker stuff to follow. I also ground down my cracks until I got to clean foam and then just filled with epoxy and a layer or two of fiberglass. Rudders are under all kinds of stresses and as they get old you can get some internal delamination between old foam and fiberglass where gaps can develop and cracks form. Injecting epoxy should stiffen-up the inside of the rudder, as well as seal it from any outside water intrusion.
tmjb
Mar 13, 2012
222
Thanks for your input. That doesn't sound like a good scenario.
However I am not sure it fits with what I am observing: The cracks appear to be mostly hairline, irregularly spaced and only one side of the rudder plus the rudder sounds uniformly solid. I also see no separation between the shaft and fiberglass at the top.
I would have thought that cracks caused by relative movement of the frame connected to the shaft and the fiberglass would follow the construction of the frame (be regular) and likely on both sides of the rudder. I would also expect to be able to detect some separation from sounding and to see evidence of greater movement.
tmjb
Mar 13, 2012
222
Many thanks. I have a few questions - again pls excuse my ignorance:
I am unclear about the construction of the rudder I have read here and there about a foam core but am unclear what that foam is and how the metal frame of the rudder (stainless?) interfaces with the foam (is the foam a filler in areas where the frame isn't - i.e. is the rudder solid fiberglass at those locations, how thick the fiberglass is outside of the foam?).
What did you use to inject the epoxy?
braol
Apr 16, 2014
348
The rudder is a round shaft to which is welded a rudder-shaped frame made of strip or thin bar steel. Around this frame is a core of two-part foam ("epoxy foam" would be the best description) with a fiberglass skin. (I may be wrong, buy I assume that a new rudder frame is placed in a closed mould into which is poured the liquid foam. When the foam hardens, the mould is removed and the rudder is then smoothed and glassed over.) The foam is REALLY hard and provides strength without being too heavy, the fiberglass just reinforces this even more and also protects the inside from getting wet. The danger to a rudder is that it develops a crack, water gets in, rusts the frame and the welds holding it to the rudder tube, and then one day you turn your wheel (or tiller) and the rudderpost breaks free of the frame and foam and there you are with a floppy rudder hanging out the back.
I'd say that the fiberglass is several layers thick. What I noticed on my rudder is that some of the foam had either shrunk or that there were some voids where the glass and foam are not touching. These gave a dull sound when rapped with a small hammer. I had also developed a vertical crack on one side of the rudder. I simply ground away the rudder glass and foam around the crack untilI reached virgin foam and then filled the crack with epoxy resin, a litle bit of fiberglass cloth, sanded it smooth, put on a barrier coat and that was it. Another place to develop cracks is where the rudder post enters the rudder, then water can get in. i had this also. What I did for that is to drill some holes near the bottom of the rudder to allow water to drain and the rudder to dry and then filled the holes with epoxy.
You can inject epoxy with a syringe (West brand sells these). Just mix the resin, suck it up with the syringe, and inject. It's best to drill an "outlet" hole nearby to allow air to escape. When epoxy bubbles out this other hole (and the hole is best to be higher than the injector hole...air rises...) the void is full. I like to duct tape over the injector holes so tha the epoxy does not run out.
When I had the pre-purchase survey done on my H37C (way back in 2001) the surveyor noticed similar horizontal cracks on my rudder. Long story short, it became a point of contention in the sale and we ended up factoring the cost of a new rudder into the price. Foss Foam in Florida still makes rudders to order for our old Cherubini Hunters. I seem to recall a new rudder was around $1500 back then. Foss Foam's website has some good pictures of how the rudders are made:
http://newrudders.com/?page_id=12
If the cracks are really worrisome, you could always remove the rudder and split it with a zip cut wheel on a grinder, inspect the SS frame, make any repairs, and epoxy everything back together. A big job but doable. I kept my old rudder, just in case I ever wanted to do this but I have yet to tackle it...:lame:
Sep 12, 2011
88
Hunter 27 Annapolis
Personally, I'd grind that out, get to glass, and let it dry. Then come back with some fiberglass cloth if necessary, but you should only have to fair it with a fairing filler and throw some barrier coat on. Have you looked at your hull too? I sanded this weekend and I kinda freaked out. I have stress cracks like that on my hull in many places. Rudder looked great though. Maybe someone already did the job. I know, rudder issues are worry some.
Try not to drop the rudder. I have done many jobs like this with the rudder in place. Looks to me like you can just grind, fill and barrier coat. Not too bad. Let us know your fix. Thanks for posting.
"Rudder's shot away sir, the steering don't answer." -Master and Commander
Apr 6, 2013
23
Beneteau 35s5 Belleville
What are we looking at in the photos in the white ? Did you sand right down to the gelcoat or is there still multiple layers of epoxy (ie Interprotect 2000) still on top of the Gelcoat ? Are the cracks just the epoxy layer or right down thru the gelcoat ? I ask because in photo 3, the triangle crack looks even whiter beneath.
Something caused those cracks and they are not small by any means. They appear to be fairly regular across the top half of the rudder. I am also of the opinion that the glass skin on the port side has seperated from the foam inside and the shaft frame is flexing inside and damaged it by pushing out on the fibrerglass skin. Maybe the steel frame is tabbed (glassed) to one side of the skin only --- hence why you only see flexing on the single side.
Do you see any water seeping out ? You might consider drilling into the core 2 inches from the bottom and see if water pours out.
Personally if it was mine, I would not put that rudder back in the water without knowing.
Maybe send your photos to FossFoam and ask them for guidance.
Good video series here to show you what is inside a rudder and how they are repaired.
https://www.youtube.com/watch?v=MRXNnFx7DBQ
May 2, 2011
63
Hunter 37 C Long Pond, NL
tmjb
I had similar cracks on my 37c rudder except mine were on both sides but mostly one side. When I hauled the boat for the season I drilled small holes in the rudder and let it dry over the winter. The foam that came out of the holes was dry. In the spring there were some rust stains around the holes I had drilled. I ground out the cracks and filled them with epoxy and glass. The next fall I I removed the rudder to do some exploratory surgery. I cut into the rudder to expose the framework. I was expecting rusty mild steel but I found stainless in good condition and again dry foam. I replaced the cut out pieces and ground out the cuts and fibreglassed over each cut.Then I fibreglassed over the whole rudder and coated with gel coat. I haven't had a problem since that was back in 2007. I suggest you drill some small holes and check on the foam that comes out. You can fill with epoxy to repair the holes. The repair Jim Legere describes is possible but it is a big job. The fibreglass and the foam stick together very well so it isn't easy to split the two halves apart.
Good luck.
tmjb
Mar 13, 2012
222
Thanks to you all so much. I now have a much better understanding of what I am likely dealing with particularly now that I understand the original construction of the rudder.
I do now see how the cracks may appear to follow a possible internal frame layout. However, the appearance is influenced by my recent partial sanding which focused on the larger cracks. There are a number of smaller, less regular cracks that I have not yet sanded the paint from.
What I believe I have is red bottom paint over grey barrier coat over white original gelcoat. There is also some possible white filler in a triangular shape near the middle of the top crack.
Before I decide what to do I think I need to remove all of the bottom paint at least from this side of the rudder (is there a better way then sanding?).
If I decide to apply epoxy and mat external reinforcing do I also need to remove the barrier coat in the areas in question or can I apply this over the top of the barrier coat. If I have to remove barrier coat what is the best way to do so?
If I decide to fill potential voids in the rudder by epoxy injection should I use penetrating epoxy or regular West system?
Again I really appreciate all the input. Many thanks.
Tim M
Oct 19, 2014
25
Hunter 37C Blaine,Wa.
Was the rudder exposed to the sun on only one side for 18 years on the hard? This looks like degradation of the gel-coat from sun and weather. On our boat the rudder had to be rebuilt professionally because of sun exposure after less than a year on the hard after being in the water for 30 years. This was the surveyor's opinion and the repair work confirmed that it was the case. I'm sure water ingress was the culprit but the damage that resulted on only one side of the rudder because it was the side exposed to the sun was much more raised in larger flat sections with 8 - 10 large cracks and not multiple hairline cracking like yours. It also followed the framework of the rudder to a certain degree. It doesn't look to me like damage caused by a turning shaft either - unless the whole interior framework is banging back and forth in there. If the rudder is still solid with good integrity of the fiberglass, sand the paint off and coat with several coats of epoxy after some 3M filler if it's not smooth enough. From my experience, boatyards and owners often neglect to properly care for the rudder as compared to the hull. Maybe initial barrier coats weren't applied and maintenance coating was minimal. Extra cloth won't hurt but might be overkill. Good luck.
Tim
Mar 11, 2015
357
Hunter 33.5 Tacoma, WA
It is guaranteed to be waterlogged.
I'd cut out the fiberglass from the bottom part of the rudder and let it drain. To do this, you may have to drill a few holes at the top so air can enter as the water drains. It may take a long time. You may be able to inject air at the top via a compressor or shop vac to pressurize and force the water out. After, grind out the cracks in the middle. Find the hollow sections by tapping with a hammer and inject epoxy.
I had to do all of this [grin].
RTB
Dec 2, 2009
152
Hunter 36_ 80-82 Kemah, Texas
I give a thumbs up to Foss Foam. We put one on 2 1/2 years ago. I think the price is about $1900.00 now. Worth it in my opinion if sailing offshore much like we do.
The yard that did the work didn't bother with removing the mold release on the new rudder, plus didn't bother to barrier coat it. It has been the curse of many divers over the past 2 years, since it was basically bare gelcoat by the time we got to New Orleans. Apparently no damage though, since we just hauled out to do a bottom job. The rudder now has 3 coats of 2000E, plus bottom paint. Ready to go cruising again.
Ralph
http://www.sailblogs.com/member/brogdon/
Jun 21, 2007
2,118
Hello RTB:
Although your RTB user name has rung a bell with me, I really haven't recalled you very much. So great that you have again "revealed" yourself as a participating Cherubini H36 owner!
Obviously I am one too.
There are too few of us that contribute to the particulars of our really well-built and good-performing 36' 1980-82 boats. Probably because not all that many boats were manufactured by Hunter. And with each passing year, fewer remain.
Hope that you continue to weigh in from time-to-time. It's not necessary that any of us know the exact answers to any posts/questions. Just replying with insights or experiences or questions can often trigger a different thought process to the best solution.
tmjb
Mar 13, 2012
222
As has been said many time before, this is such a great resource and I am so appreciative to all who have responded to this is.
I now have a mcuh better understnding of the issues involved, ideas of what to look for and possible fixes.
I need to spend some more time investigating my condition and thinking about what to do in my circumstances.
I will post the results once I have them.
One question that I asked that hasn't been resounded to relates to the barrier coat. I am assuming that any epoxy work i may do on the exterior requires me to remove barrier coat in the effective area to get back to the original gelcoat - is this correct? Assuming so, is there a better/easier way to do it other than sanding with 80 grit?
Most barrier coats are epoxy based. Epoxy's adhesive properties are pretty good. My feeling is that clean (free from antifouling) barrier coat that was properly applied and is well bonded to the gelcoat would be a suitable substrate for further epoxy based products such as epoxy putty or fairing compound...you could contact you epoxy manufacturer's technical support to be sure.
RTB
Dec 2, 2009
152
Hello RTB:
Well, I do check here from time to time, and enjoy offering my thoughts if it's a topic I can help with, so thanks for the welcome.
Actually, we have run across a fair number of 80-82 H-36's in our travels. I guess 8-10, which actually surprised me. There is one here at Cove Harbor in Rockport, besides mine. I also recall one anchored off Gulfport, Florida. It was a derelict with no engine, but a couple living aboard. Also, met up with some fellow Texans in Boot Key Harbor last year, aboard Moonlight Sue - http://www.sailblogs.com/member/moonlightsue/?xjMsgID=319464
Our Hunter has been great so far. 5000 miles in the past 2 1/2 years. We have lived aboard since Aug 2012.
My thoughts for the OP.....these boats are getting old, but have some good years left in them if you take care of the boat. A lost rudder can easily require abandonment if offshore in bad weather. Do you really want to risk it? Keep everything good below the waterline - new, or at least closely inspect thru-hulls and hoses. If you're good below, not much chance of sinking. My standing rigging is old, but still passes inspection - no candystriping or meathooks. Still, new rigging may be on the list in the near future. Just my 2 cents.
Ralph
