Did some searching and found a few opinions, but not a lot of luck getting some facts on whether having a longer distance 7-10' between batteries in a bank can pose a problem with charging, etc.
I'm considering moving to 6v golf cart batteries for the higher AH rating available, configured for 12v setup, in which case, I could get 2 in the original location, and the other 2 would be a ways away. If I have the appropriate gauge wire between them to carry the amperage, will this work out, or will I have more problems.?
My alternative will be to do a bank of 2 Group 29's which will fit in the current location under the companion way, allowing a separate reserve battery for 3 total.
