My new mast raising pole arrived yesterday, so we were excited to give it another bash. That's good. Got everything in place and went to set the pole, only to find the guys at Hunter cut it wrong. They drilled the holes east/west rather than north/south. The bad. Incredibly, we found a rigging shop down the street that drilled new holes in the pole and rigged new eyelets for $40. That's good. Got the mast up and furler attached. More good. Noticed though, probably residual damage from the pole bending, a crack in the mast foot or base. Looks bad. Am sure it happened when we bent the pole over. Mast was pulled quite a ways to the side.
So the question is, how bad? You can see the crack in this pic. I noticed when I bought the boat that some rivets at the bottom of the mast were bad, so the area needs work anyway. How dangerous tho is this? Note, I am a timid sailer, especially with a new boat. So am I okay setting sail in under 10kts?
