New Yanmar 3YM30AE noise at shut down
Ed D
Nov 22, 2009
39
Hunter Vision 32 Jacksonville Florida
I have a brand new 3YM30AE which I am most happy with However when I shut down the engine with the off button on the panel and the engine in neutral there is a clung sound for a split second I asked my dealer and he said it is the shaft making the noise because of the fast shut down My question is this normal
Ed
1,146
Does this happen every time or is it intermittent?
Did the dealer tell you which shaft is making this noise? Or how shafts could make such noises? Seems like it can't be the propeller shaft since it is not moving. Gearbox output shaft is sitting still too.
Can your dealer obtain written reports from Yanmar - or anybody else - verifying this phenomenon?
Charles
Nov 6, 2006
10,107
shaft hitting inside of stern tube/packing box holder during that last hard shake before stopping? Alignment good?
ALNims
Jul 31, 2014
208
Hunter 356 Huis Ten Bosch Marina, Sasebo, Japan
Ed
I would like to suggest that you contact Yanmar technical and give them a description of the concern. Your engine is new and should be under warranty.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Check
Can you have some one down below listening for the noise when you shut down
and what is the idle RPM and maybe the idle RPM is high.
Nick
