Fuel consumption rate
Sep 14, 2014
11
Catalina 390 Middle River, MD
I have a C-390 and I want to know my GPH. Does anyone use a standard rate or can someone forward the calculation please.
Wes
Summer Wind
What engine? HP?
Our M25 21 hp gets 1/2 GPH. The M35s get 1.0 GPH.
May 13, 2013
42
Beneteau Sense 50 San diego
Yanmar publishes fuel consumption curves. Rules of thumb. Cruise at 80 percent of max continuous rpm. Cruise speed will be 1.2 Times Square root of waterline length - flat water. Power will be 50 percent of max power and fuel consumption will be 1 gallon per eighteen horsepower. Most cruisers have 2.5 hp per thousand pound light displacement.
Biggest caveat is correct prop pitch. But bottom and other stuff may affect it
Nov 22, 2011
1,192
Ericson 26-2 San Pedro, CA
Your fuel consumption number sounds high to me. On my previous boat, a Catalina 30, I had a Universal M25XP, which was 23 hp. It only burned about half a gallon per hour. On my boat before that I had a Universal M18, which was maybe 15 hp (?) and it burned a bit over a quarter gallon per hour. And in both instances I typically ran the engine at about 80% of max continuous rated RPM.
May 13, 2013
42
Alan
Your numbers should be right. At 80% RPM which is about 50% power a 23 hp engine should be running at about 11.5 horsepower which is about .6 gph.
Jun 9, 2004
615
Catalina 385 Marquette. Mi
My usage is about 1 gph @ 75%. Which is pretty darn close to Yanmar's charts. 3JH5E.
Nov 22, 2011
1,192
Alan
Good point! Thanks for clarifying that for me.
