I'm possibly a bit slow here. I have a C-310 with M-25 XPB with a hot water heater. The hot water tank is in the rear compartment just forward of the rudder post. The water is heated by running engine coolant through a heat exchanger in the hot water tank.
Question: When changing the coolant, how does one drain the coolant from this heat exchanger and associate hoses.
The picture shows the coolant hoses running to the hot water heat exchanger from the pump on the front of the engine.
