PVC used on the walls in the head on my Catalina 30 MKIII
Due to some deck leaks I had to cover the walls in the head. I saw a Lynn Morse yacht at the Annapolis sailboat boat show (attached pic)that used PVC panels on some ceilings and the forward bulkhead that looked impressive. I found similar inexpensive PVC board in Home Depot along with PVC molding. Since I had to cover the walls anyway, it was an opportunity to hide all the unsightly hardware on the bulkhead by using furring strips under the PVC board using Goop adhesive (similar to silicon adhesive). All moldings are PVC from Home depot and are very easy to work with. They cut easily, are flexible and can be rounded off.
