I want to know what is being charged by the motor and is this properly wired?
Thanks
Ted
Thanks
Ted
Yes, it is important to have matched batteries (new, same brand, same specs) because when you hook them in parallel (all), the batteries will try to "balance" each other out. If the batteries are not matched (voltage), a "circular" current will exist between the two (yes, they get hot), until an equilibrium is obtained. At this point, charging from the alternator will work, on both batteries, equally.
Regarding the combiner, that is more related to isolating a third battery (a starting battery) from being drained when using the house batteries. How it works is when the voltage is high enough (13 volts, either from the alternator or AC charging system) the third battery is in the charging circuit. Once the voltage reaches a certain level (i.e. 13.8 volts), the battery is disconnected (via a physical relay).
I should add that this ONLY works if the alternator is putting out good voltage (13.8V). If one diode is burned out (happened to me), and it is only putting out 11 volts, then the starting battery will NEVER charge. In my case, I solved this mystery by installing a 3-way voltage meter so now I can tell if the alternator is putting out the correct voltage.
http://www.cruisersforum.com/forums/f14/xantrex-echo-charge-vs-blue-sea-acr-81980.htmlI am following this thread...and plan to parallel my two 4ds and add a group 27 for a starter battery on a 1/2/all switch. Have read Maine's advice on batt switches l. What is the advantage between a combiner vs an echo charger?
Why a group 27? Why keep the two non-deep cycle back breakers?I am following this thread...and plan to parallel my two 4ds and add a group 27 for a starter battery on a 1/2/all switch. Have read Maine's advice on batt switches l. What is the advantage between a combiner vs an echo charger?
Right. Skippers, there's really no reason to retype thew same stuff, over & over. Try these (includes Maine Sail's thread):Most likely the alternator and starter share the red wire back to the selector switch. Under this configuration the alternator only charges the selected bank by the switch. Can't link because I am responding on my phone, but do some reading on The Musings of Maine Sail. There is a sticky on 1/2/both/off switches.
A combiner is a relay that parallels banks when charging is available.I am following this thread...and plan to parallel my two 4ds and add a group 27 for a starter battery on a 1/2/all switch. Have read Maine's advice on batt switches l. What is the advantage between a combiner vs an echo charger?
Because.........they are brand new batteries in a brand new boat. 6 volts to follow.Why a group 27? Why keep the two non-deep cycle back breakers? http://www.pbase.com/mainecruising/deep_cycle_battery
