Water Ballast pump out
Apr 24, 2006
868
Aloha 32 Toronto, Lake Ontario
A quick tip about "blowing ballast".
We always remove ours before hauling out - makes it much easier to get up the ramp.
We use an air mattress infiltrator with enough tape wrapped around the nozzle to make it fit snugly into the ballast vent.
But what we found made a huge difference in how long it takes is to have something push downwards on the ballast valve after it's opened. If not, a lot of the air pressure escapes.
Chris
Aug 7, 2011
496
MacGregor 26S Lakeland, FL
But what we found made a huge difference in how long it takes is to have something push downwards on the ballast valve after it's opened. If not, a lot of the air pressure escapes. Chris
Not sure I'm following what you mean, or why. Please explain? Thanks!
Apr 19, 2012
1,043
O'Day Daysailor 17 Nevis MN
As the pump is pressurizing the ballast tank air will leak out of the top of the valve around the threaded shaft. If you hold the large wing-nut down, it seals the large rubber gasket (you might call it a washer) against the top of the tank thus allowing more pressure inside the tank to push the water out the bottom.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
sort of "amusing"..
In that link earlier, I think that boat (water ballast) would probably still float just fine even with all that damage as it looks to be all under the ballast tank. I dont even think the inpspection hole would need to be tight.. just dont add any weight to get the inspection hole below the water line - then it would be going to the bottom fast. If the inspection hole were tightly sealed, it would even float fine then. It would have no righting moment however.. not a good idea to raise a sail.
Yes Walt it did float fine. No leaks. I found that out right after the guy that sold it to me told me it was an extra $350+ tx to put it on my trailer with his lift! I towed it about 1km to a ramp and paid $15. I did bring a new ballast vent plug with me when I picked it up.
I floated the boat off, pulled the trailer out, unhooked it, Took off the 1 7/8" ball, put on the 2" ball, hooked up my trailer and loaded the boat.
I was in conversation with a boat builder tonight about fixing the hole. It should take 2 days on the lift. I will video the process and post it on my webpage for everyone to check out.
If I didn't have access to a boat lift I would have passed on this boat.
That baffle from the link is a baffle. It does not provide any strength to the floor above. (I don't think it touches it.) It is just stuck to the bottom of the ballast tank/ hull. (Not very well either.) That's what makes me think it is a baffle. (Probably not the smartest placement or design... Who knows what they were thinking back then.)
Oh. When I pulled that boat out of the water on my trailer the ballast tank emptied almost instantly!
Aug 7, 2011
496
Thanks!
sunman
Jul 29, 2009
112
Mac Mac 26D Suwannee
I use "Air Pump" method, and Ive never sceen the washer lift off its seat and loss of pressure,
when I open the valve, and push the rod/wingnut down, it stays there, and the ballast emptys in a few min..
I will say this about that, I did install sched 40 pvc fittings in the tank opening and reworked them to accept the air pump, and keep it attached tightly while running w/out duck tape etc. so I can continue to get Berea ready to haul-out, when done I put on the pvc end cap to the close the vent off, close the valve, DONE!
at one time in the past we had a blog about this, and some were saying to tight and you could split the ballast tank etc.....if thats the case, the safety valve would be the washer acting like a pop-off valve.
just make ur pump fit snug to the opening and not fall out, open the valve push the wingnut and washer down turn it on, and go do something, when you see air bubbles around the water line, Ur Done
Nov 19, 2011
1,489
MacGregor 26S Hampton, VA
That's a good point and I don't recall it coming up in the other thread that the washer would act like a relief. I should do this but I just drain it on the ramp
Apr 19, 2012
1,043
I enjoy seeing all the on-lookers gasping in horror as all that water pours out on the ramp. :eek:....:D
May 11, 2014
156
Catalina 22 Lake Pleasant, AZ
a friend of mine had a Mac and one of us would always yell "empty the porta potty" before starting to drain the tank at the ramp. The looks on peoples' faces - priceless!
sunman
Jul 29, 2009
112
hauling out a boat w/1100lbs of water aint as easy as an empty one
goes back on the trailer like she came off, but U do as U want, I dont mind running the pump while Im doing this or that getten her ready to load on the trailer, take about 5-10 min, before U leave the boat to get her on the trailer, close the ballast, turn off the pump Ur done, at my ramp I have to step the mast anyway while in the drink, power line:eek: so my time is spent doing what U prob. do on the hard, so I empty the ballast at the same time, takes about 30sec to install the pump, if that
Apr 27, 2015
2
MacGregor 1990 26S or 26C Clearwater
I'm a MacGregor rookie and just got my 26S less then a month ago. I was thinking about just putting a hose from a bilge pump down the ballast vent hole and the exhaust hose into the galley sink to drain out. Does anyone have any thoughts on whether or not this would work or have any pros and cons to this idea?
Nov 19, 2011
1,489
Seems to me the drain on the sink would be the limiting factor. It's not able to handle a lot of volume. Seems it would take forever to drain it but if you have time, seems one way to do it while on the water
