Although Capta has a valid point, the key to keeping power requirements down is counter balance. Again, let me use the satellite dish on a cruise ship analogy.
First, the dish is in a radome so there is no outside forces such as wind to fight with the motors. However, cruise ships are not always in fair winds and following seas. They get beat up a bit. The antenna is designed with weights for balance and counter balance. If and when the dish is pointed at the satellite, no matter how much yawing, pitching, and rolling is going on, the dish remains locked on the satellite. The key is, as mentioned above, good bearings and well balanced.
If the solar panel were well balanced, it does not make any difference what the boat is doing under the panel. It will remain pointed at the sun. The motors are there to just make minor alignment changes.
Again, the key is "well balanced"!
As for the GPS, true, it might not be needed, but at least ones lat and long are required to make the calculations for sidereal tracking of any celestial body.
