I upgraded most of my interior lights with LED bulbs. It was very easy once I knew what to order and actually cheeper then the old incandescent lights. Heres the info; enjoy...
Festoon LED Bulbs: 31MM, 39MM, 42MM
Simply search on google for suppliers of "Festoon LED bulbs". My boat uses the 3 different sizes listed above. I counted all the sizes and ordered in bulk. The lumens rating are different for each supplier so if you need extremely bright bulbs then that should be a focus. All LED bulbs need to be installed directionally so if they don't work after installing, remove and rotate. Make sure you buy the correct voltage i.e.12V, 24v, etc..
I replaced all my nav lights and mast lights as well. If anyone knows how to describe the bulbs below (belong to reading lights) in the picture I plan on replacing it as well.
