Couple of bow pics with and without hardware first pic showing stem fitting still attached
View attachment 84993 Bow minus anchor platform
View attachment 84996 Starting clean up
View attachment 84996 View attachment 84997 Bow with anchor platform
I'm a bit concerned as to what I'm seeing in your pictures. Like I mentioned in my e-mail. My boat is built a bit different so we will need to rely on the others to take a careful look at their boats.
I see the "anchor platform" off centered to the starboard side. Forward hardware often gets replaced in boats this old. It seems to be easy targets for pilings and such. It may not be original and being offset is not necessarily bad, just something you should carefully understand the "why" behind it. I googled some photos of other 37's and did not see this same offset. Maybe it's simply for anchor clearance but I think it's wise to question previous owner's work. Most importantly, take a careful look at the strap that appears to have been under the plate. This is very suspicious. What was attached to this strap?
Also from pictures from other O'days 37s I see a strap (bowsprit plate) attached to the bow running vertically down the bow towards the water. This should be the attachment point of the forward stay. Is that the case with your boat?
I'm also concerned about the need to open and gain access under the anchor plate. O'day does not put bulkheads or supports in locations without a need for them. Can someone help them and confirm if such a bulkhead was original to the boat? I just don't know what the purpose of such a structure is.
I'm mentioning this now because it's the perfect time to get this all straightened out if needed.
The most obvious flag that drew my attention is the fact that the plate was never bedded properly. It cries out uninformed DIY. Did you find backing plates on the inside under the anchor platform?
