catalina 22 80's version
Feb 10, 2015
1
catalina 22 corpus christi tx
Does anyone have the standing rigging specs for a catalina 22 ?? approx 1984
Sep 8, 2014
2,551
This is posted in the C22 boat owners Boat Information tab.
http://catalina.sailboatowners.com/...id=257&cat_id=107&aid=6064&page=article&mn=22
Hope it helps.
I have the same boat, and the same drawing... Am I reading this right? Mast is 24' 9", then below for each wire take the mast dimension plus the listed dimension for each shroud/stay eye to eye?
So...
Standard backstay = 24' 9" + 35" 1/4 = 27' 8 & 1/4"
Headstay = Mast + 17 1/2" = 26' 2 & 1/2"
Upper Shroud = Mast + 5 1/4" = 25' 2 & 1/4"
Forward Lower = Mast + 5 1/2" = 25' 2 & 1/2"
Aft Lower = Mast + 6 3/4" = 25' 3 & 3/4"
Not sure if that's right because the chart at the bottom of the pdf page says the std backstay should be 28' 2 & 1/4, 6 inches longer than what I got.
I still have all my old standing rigging, coiled and labeled. I planned on measuring it all anyway to verify. I'll post my results. I was hoping to build all my own new standing rigging myself, with the exception of having the swages done at a rigging shop. I can get my 1/8" 1x19 wire for .40 foot, and I want to use swage ends rather than nicopress fittings.
Jun 1, 2004
8,346
From 1987 Owner's Manual, http://sailingfortuitous.com/sites/default/files/1987_Catalina22_Owners_Manual.pdf (length.... wire diam... type... number. All wire is 1/8" 1x19)
BACKSTAY STANDARD 28' - 2 1/4" 1/8" 1 x 19 1 piece
FORESTAY 26' - 5 1/2" 1/8" 1 x 19 1 piece
UPPER SHROUD 25' -3" 1/8" 1 x 19 2 pieces
FORWARD LOWER 12' - 10 1/4" 1/8" 1 x 19 2 pieces
AFT LOWER 12' - 11 3/4" 1/8" 1 x 19 2 pieces
MAIN HALYARD 60' - 0" 5/16" L.S. DACRON 1
JIB HALYARD 63' - 0" 5/16 " L.S. DACRON 1
Note: MKII model introduced in 1995 has wider beam.
caguy
Sep 22, 2006
4,004
A friend of mine use the Norseman swageless fittings. They are pricey but you can assemble them yourself.
Sep 8, 2014
2,551
Wow, I was waaaay off! I should have known since I'm well aware the lower shrouds are only 1/2 the height of the mast. So can anyone tell me what the heck is up with the drawing on page 14? How did I misinterpret that?
