new prop or is tach off
Aug 3, 2009
109
Catalina 30 great neck, ny
Good day to all of you shoveling out of the mess left by the last snow storm.
I am passing the winter thinking about upgrading my boat - a Catalina 30 with a Universal M18 engine. I have been on this site many times trying to get an idea of what I can do to confront the ageless problem of low engine performance and have had many suggestions from all of you.
The latest chapter is as follows: The boat in on hard and I removed the prop and took to a shop where they showed me that it was undersized. The specs call for a 13X10 and this one was a 12X7.
I have the opportunity to get a collapsible one (two blade) that is 14X10. The shop told me that it would work but that the RPMs would be reduced because of the size change. I remember that the RPMs at WOT engaged in forward was about 2100. I believe that it was about 2300 in neutral. (after adjusting the governor).
I do not know if the tack is accurate. I am afraid of backing off the adjustment screw for the governor any more. Are there any suggestions of how I can test the tach for accuracy? If it is accurate, why am I getting low RPMS?
Jan 4, 2006
7,268
Hand held optical tachs are cheap enough that you could get a few of them and take an average. I would think you should get a reasonable figure (+/- 5% error at worst) with one of these. It's a start to see what you're dealing with between the engine and the mounted tach.
According to Gordon Torresen
http://forums.sbo.sailboatowners.com/showthread.php?t=8532
your engine has a max RPM of 3200 and a cruising RPM of about 80% or 2600 RPM.
The mounted tach may be a little ............:doh::doh::doh:.
