Very hard to set and fly a symetrical spinnaker if single-handling. Because of this, I went with an A-Sym. Unlike Allan however, when I fly mine it is set in front of the head-stay. Tack-line is on a block set on a bail at the front end of the anchor roller. I can adjust the height of the tack as needed. I single hand most of the time. So, I use a sock which gives me easier control when setting and dousing. The 34 is a mast head rig, and the A-Sym is quite big. Mine is shoal draft, very tender boat and indeed it is easy to get overpowered with the A-Sym when the wind pipes up. A-Sym will not allow DDW so you will need to learn to gybe it properly. Not hard but can be tricky in shifting winds. Also, because of the swept back spreaders, the main has a tendency to blanket the A-Sym in very light winds and I generally get more speed when dropping it to help the A-Sym stay full. In that case, I can also get to very close to DDW because it stays full longer. Of course you need to trim accordingly and watch it constantly. By and large, I love mine and use it frequently but I do agree with Allan that borrowing one and trying it before spending the $$$ would help the decision. If you are lucky enough to have a friend with one with approximate dimensions for your boat, ask him out for a sail and tell him you'd like him to set it up and fly it on your boat. Trying it by yourself unless you've flown one before might get tricky. Good luck.
