Myth busters
Beneteau 323 Annapolis MD
"Of course I'll respect you in the morning- just as much as I do right now."
Oct 17, 2011
2,809
Ericson 29 Southport..
Did somebody lose a bet and shoot the chart table? :) Jeff
Just a dark spot that has been there since the Lord came over on the Mayflower, I hardly notice it anymore.
The 'max speed' was what I was referring to..:)
Oct 2, 2008
3,814
Pearson/ 530 Strafford, NH
Did you hook up a drill to the little paddle wheel? Hahhh "Starts with one or two Pulls"
All U Get
Oct 17, 2011
2,809
It actually IS mysterious. Really, I couldn't tell you why that says 19 knots, because I certainly do not remember it..
walt
Jun 1, 2007
3,556
the peak speed reading on your GPS is always dead nuts on..
(my Elite 4 with a GPS peak speed reading showed over 20 mph peak speed when left on during the day and the boat was sitting on a trailer in the driveway)
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
I've got a couple of minutes of video sync to the GPS or 18 mph. The boat was barely moving.
I received a speeding ticket a few years back where the ticket stated I was clocked/paced with GPS. Makes me wonder if I should have fought it.
Nov 8, 2010
11,386
That is not entirely true.
GPS subsystems calculate speed over ground (SOG) by one of two methods.
1) Distance delta between two location readings take one second apart
2) Measuring actual doppler shift at the time of a reading.
Both mechanism can generate spurious readings due to signal multi-path, and/or rapid short moments near the antenna at the time of the reading. When this happens, the speed reported to the device is NOT the correct speed. But many devices simply report this anyway, because in the bigger picture it does really do not factor.
But for devices that care to report accurately (like top-end sail racing gear), there are steps they can take.
1) Have a max G acceleration factor built in. Boats cannot be going 4.4 knots one second, and 19 the next. Or even 7 then 19. If you know fast a boat/car/etc can accelerate, you know how much the speed can change reading to reading. Throw that point out.
2) Run an average of N points to report high speed. Simple but not as good as #1
3) Report an SUSTAINED high speed. Like for 10 or 20 seconds.
Here is a Velocitek ProStart, showing a top burst speed of 11.2 knots,controlled by rule #1, and a sustained top speed of 10.1 for 20 seconds.
Thats real.
Feb 20, 2011
8,062
Interesting. Is your vehicle equipped with a GPS transponder device that you're unaware of?
Maybe look in the fenders, wheel wells or on the undercarriage? ;)
6,244
S2 9.2a Fairhope Al
how much was the fine it may have been cheaper to just go with the flow..... if you have no history of speeding then it would be your call ..as for clocking with a gps that is not an accurate way to tell example if two cars are going the same direction and the lead car is going 70 mph the second car always has to go faster to keep up ...cant explain why just know that is what happens
Feb 20, 2011
8,062
snip...example if two cars are going the same direction and the lead car is going 70 mph the second car always has to go faster to keep up ...cant explain why just know that is what happens
Whiskey Tango Foxtrot?
Jul 29, 2010
1,392
Macgregor 76 V-25 #928 Lake Mead, Nevada
1.Don't worry honey, a sailboat has the right of way over a tanker.:cussing:
2. I can get out of West Marine for under $100.00:eek:
3. I made sure we have everything we need before we leave the slip;)
Sep 20, 2014
1,330
Thats real.
I have a Sony POV camera I use on the boat which has a built in GPS. Every so often it gets very confused and reports sustained higher speeds over a very extended period of time. Since it is also reporting position, It showed I tacked, when I didn't. This was probably over 400 feet off course. Then it showed I tacked back. all at about 18 mph. There may be something weird going on on that lake as the cell phone has also reported some sustained erroneous speeds in same area.
Nov 8, 2010
11,386
I would never trust any GPS that had a SONY label on it. It's not their core business, and they will never sweat the details.
Many factors in multi-path will create errors. There are tricks than can help sort them, better design helps, as does advanced technology like WAAS. Here is an interesting picture of 6 different GPS modules walking around a building. The true track in thin yellow. The wild tracks and quick returns to close approximate true position will generate huge spikes in reported speed. If you don't deal with that... hey 19 knots! ;^)
