Projects for your Siruis...what have you come up with
I used to keep the stern anchor in the small cockpit locker and it was always a hassle to get it out and deploy..being the motor is on that side too. Leaving things to the last minute as usual I cobbled this together out of some 3/4 inch PVC scraps and a few plumbing fittings. Worked great on out last trip. It may be ghetto but it sure beats paying for the expensive stainless steel "boat hardware". This is the prototype mark I version and I am sure it could slim down on the next version...someday.
The solar panel brackets show up in this photo though the lower one is hard to see against the rudder. Also made from PVC scraps. The panel rotates and tilts and locks into position
You can see I robbed it of a bolt and nut to fix something else on the trip...guess I should replace it.
You can see the top bracket for the solar panel in this photo. The offset groove cut into the anchor bracket allows clearance for the inside bent edge of the fluke when the anchor is taken out or put into the bracket.
While sailing I leave the chain hooked to the anchor and then when we pack up the boat I slip the chain onto the hook in the PVC cap and it holds it in place while trailering.
Once the anchor is set into place it locks into the bracket and does not move or flop around.
Here you can see the anchor bracket and the solar panel mount...from a distance. The panel mounts on the pole a bit off center for more clearance on the boarding ladder.
