Myth busters
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
Sustained speed in flat water???
This pegs my BS meter.
Pictures or it isn't true.
That boat has a ton of overhang on the stern, so the waterline is heeling dependent - looks like by several feet. There is at least one decent YouTube video of one under sail in a solid breeze. You can see the wave build up at the bow, so I don't think it will cheat hull speed by much.
In contrast, my boat, which planes easily, there is almost no bow wave at hull speed. Displacement to planing has no transition, the boat just goes faster.
Nov 8, 2010
11,386
I agree with your other points. To this point, the square root function is the great humbler of numbers. Even if you were to use the LOD overall hull length and not the LWL, the speed difference is less than 1/2 a knot.
Sep 20, 2014
1,330
Stupid math just kills the imagination LOL
Jun 1, 2004
8,346
You have to ask why it is THEORETICAL Hull Speed.... rather than the LAW of Hull Speed Theory?????
The myth is NOT the theory, which is a simple formula for determining optimal power application for a full displacement hull vessel.
The myth is that people think the theory is an absolute law of physics...
Jun 2, 2007
404
Beneteau First 375 Slidell, LA
And really, the formula as given is an oversimplification, if you consider that a Hobie cat flying a hull going 12 knots is still in displacement mode. There should be a term in there for length/beam ratio, probably disp/length ratio, etc.
walt
Jun 1, 2007
3,556
No, theoretical hull speed is exact. You can neither go slower or faster without warping time.
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
This is one of my favorites and I actually believed it, due to how credibly it was taught me, till my cousin Rick, who is ABYC in yacht electrical systems, asked me why on earth that should make any difference; and I had to think about it.
Still don't know why it's so important to take the negative lead off before the positive one, though. As long as you don't bump something against the wrong other something, you should be okay... right? (I acknowledge that's a big 'if'.)
In a negative ground system the chassis is ground, assuming of course that the chassis is metal. If the negative cable is removed first the chassis is no longer at negative potential. If you touch the chassis with the wrench, while removing the positive with the negative removed, there is no opportunity for a spark.
The spark is an issue for the wrench but more importantly, the spark can ignite the battery gasses causing the battery to explode. This is more likely when the battery is older or dead. Usually when you want to change the battery.
It is a best practices procedure.
Nov 11, 2014
1
Catalina 30 Columbia River
Myth # Infinity...
"Don't worry about a thing!"
Sailing is just like fun... Only different!
Oct 2, 2008
3,814
Pearson/ 530 Strafford, NH
Re: Myth # Infinity...
And the one you'll never hear "I'm done with my rant"
I filled the spare tank
All U Get
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Also taught by the U.S. Air Force.
