Arch Speakers
Dec 22, 2013
23
Hunter 36 Lake Erie
New replacement arch speakers in process. Stopped at manufacture to check out the progress. This is the second one I have had made, updating to Fusion Speakers and Lumitec LED lighting. Should be complete in a day or so. Choose to have it fabricated from teak and starboard.
Likes: gmiller131
Jun 1, 2009
1,860
Hunter 49 toronto
Hi,, like to weigh in on this
I have a 49, and had speakers in a pod up in the arch.
Firstly, the speakers were junk. (No surprise, as it's not something a lot of people appreciate)
But, more importantly, they are totally in the wrong spot.
What I did, (and I can send lots of photos) , is I got rid of the arch box altogether .
What I did was buy a great set of outdoor box speakers, and mounted them underneath the stern seats.
Of course I put in a 200 watt power amp to drive them as well.
The thing is that by putting the speakers in the rear of the cockpit, it just fills it with sound.
You can get very good quality outdoor box speakers from a number of companies.
You might want to think about this.
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
What art says is true...depends on how demanding you are about your music. I just purchased and mounted a pair of Bose 151 outdoor speakers that were on special at Costco and mounted them on my arch. They hang down a bit more than the Duals that I had mounted there before but they sound much better. The 5 inch speakers that were mounted there from the factory were severely lacking.
Sep 11, 2011
431
Hunter 41AC Bayfield WI, Lake Superior
On our 41 I drilled weep holes on the low corners of the over head box to make sure that no water built up. It has worked well. My original speakers did not make 5 years.....we are now on season 5 with the replacements and all is good. Yes the speakers are weak, but they are out of the way.
Feb 25, 2014
95
Catalina 30 Grand Lake. Wyandotte, Ok.
For those looking for really quality sound check out Wetsounds. They make speakers just for marine use and they are number one in my book.
Jun 22, 2006
57
Hunter H33 Topeka, KS
I think I would like to add a good set of box speakers under the dodger- they'd stay dry and out of the sun and the sound would be coming from the front, which I think would be preferable. I have an '07 h33. I'm not sure how to rerun the wires. Does anyone have any suggestions?
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
Nice design, will complement the cockpit. I replaced our arch speakers last season, I got 10 years out of them, used another set of Sony's. Good quality speakers would be wasted on me, too many years of motorcycles, chainsaws, etc. They are only used for some quiet background music while dining in the cockpit so the arch is the best spot for us and we don't disturb anyone else with our music.
Post a picture of the finished project, great idea, Bob
May 16, 2007
1,509
Where are you these days. Did you make the Bahamas?
Hey Jim, hope you are doing well and getting in lots of sailing. Yes we did make the Bahamas. We are back in Canada for the summer, we will go back again next winter. Quite enjoyed the Abaco's looking forward to cruising the Exumas next trip.
Take care, Bob
Jul 13, 2014
6
Beneteau 40 Erie, PA
Re: Hi,, like to weigh in on this
I like the idea of mounting speakers under the stern seats - please send along some photos when you get a chance. Thanks!
Nov 26, 2012
5
Hunter 326 DCYC
Speaker Pod
I would like to do the same. This looks sharp. Please send pic's and drawing if you have them to see final product. Were you putting the starboard on the back side of the teak and mounting to the arch?
Tks
Mar 5, 2013
50
Hunter 45CC Lake Erie, Sandusky Bay
I redid my arch speakers by purchasing a factory blank holder from Hunter. Had them ship it to me blank with no cut outs. I installed Bose speakers. I took the existing center light out of my old panel installed it in the new one, hooked up to a wireless control, purchased on Amazon, that is controlled by a key fob. I also added two LED lights that swivel, tilt, turn white blue or red, and can be dimmed. LEDs are only 11/2 inches long, so they are a problem for head room. Sound is awesome. The LEDs are perfect for night travel or at the dock reading. The wireless remote is perfect for approaching or boarding at night. My fob works line of sight. I can activate lights even before entering pier, 100 yds. Plus. I am very happy with this retrofit.
Jun 1, 2009
1,860
Hunter 49 toronto
Sorta did the same think, but little better
In my opinion,,,of course.
So, here is what I did.
Firstly, having speakers in the overhead pod, regardless of quality, just doesn't sound as good as high quality box speakers mounted under the stern seats.
By mounting the speakers under the stern seats, you get a wonderful surround- sound effect in the cockpit.
Furthermore, you can get much higher quality box speakers than ones you need to cram into the overhead arch pod.
So, here is what I did,,
I bought a new pod from Huntet, and junked the original. On the overhead pod, I mounted 2 light fixtures in the spot where the original speakers were. Not huge lights. Just small 3" units
And then I mounted a dimmer on the pod.
This is really wonderful, cause you can have the cockpit lighting go from candlelight intensity all the way up to real bright. The original overhead light in the pod was just on/off. The dimmer is a fantastic uograde.
I kept the Sony cd unit in the pod, but didn't wire them directly to the box speakers.
I put in a 200 watt power amp, which is mounted in the aft compartment. It is a Pyle Amp, which is marine rated and sounds great.
Now, here is where I got a little fancy.
Down below on the 49, there is the Bose stereo, which sounds wonderful.
But, I wanted the option to "fill the boat" with sound.
On the Sony CD unit, it has an Aux sound input.
And the Bose system has a line level audio output.
So, I ran an audio feed from the line level Bose audio out to the Sony Audio input.
So, you can run tunes on the Bose, switch the Sony to Aux input select, and you now have your interior Bose, and the cockpit with a 200 watt power amp cranking out serious neighbour- disturbing tunes. This definitely GOES TO 11. (As per movie Spinal Tap)
I can't tell you how great this is while flying a Gennaker blasting downwind at 10 knots, sitting on the foredeck on autopilot, and having your boat sound like the showroom at Best Buy.
Only downside is that you need the inverter running cause the Bose runs off 120.
This whole setup was actually pretty inexpensive.
The Amp was approx $120, and the speakers were about $150 for the set.
Just took some time to wire it all up.
Jun 11, 2011
1,243
Hunter 41 Lewes
I use Ultimate Ears Mini Boom wireless Bluetooth speakers. They are rechargeable and sit on the cabin top between the companionway and the clutches. The outside is kinda rubber coated and they haven't moved yet on any point of sail. They are not stereo, but the sound is very good. The problem with the arch speakers is they need to have an enclosure behind them.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Wiring
My arch speakers wiring just got corrosion from my ocean sail from NY to Fl
and what I did was replace the speaker with good JB speakers and coated with
electrical lube and put Led light and sorry no teak on out side for me and yes
looks good for sure and if you don't have arch nav pod than i would add box speakers maybe under seats and so much easier for sure.
I did change my radio to wireless remote so now I can change channel and sound from the helm when sailing and that is the best thing is great.
Nick
Jul 13, 2014
6
Speakers under stern seats
Artboas - would you please either post or email me directly some photos of the speakers you mounted under the stern seats? I hate having music blasted straight down at me while at the helm, so those sound like the way to go. Any tips/tricks for install would be much appreciated as well. Thanks in advance. Ross
