Wondering if anyone could assist me with reviewing a SeaLand holding tank toilet installation. I'm not sure if I need a vented loop of not between the toilet and the macerator pump? I am going to run the pump out line up to the deck through a three-way valve, and on the other let from the valve directly to a macerator pump and then to the sea cock. I believe this will provide me with good protection from siphoning, as I will have the sea cock to close, a macerator pump in line and a three-way valve. Is my thinking correct? The toilet, pump and sea cock are below the water line, but the pump out and 3 way-valve are above.
Thanks for your help!
