Impellers
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Well I went to check my Yanmar recently and checked my 2 belts and changed the water pump belt after finding a kind of cut on it and while checking the impeller found one of the vanes missing and after just coming back from cruising
for about 3 weeks with much motoring and will check everything more before
going on one of our longer cruises and the motor did run great.
After finding the vane gone i decided to take the heat exchanger on my 2007
3YM30 and found 2 vanes in the front part of the heat exchanger and also some
sea grass but all good now.
Nick
1,300
Columbia 36 Muskegon
A lot of sailors only change their impellers "when they need it". The trick is, how do you know when they need it? When the engine over heats? They should probably be changed at least once a season, more if your season is long. An impeller can look just fine right up to the point when the vanes break off, so it's best to be ahead of it.
There should also be some type of strainer on the intake to keep the junk put of the exchanger. Where I'm at we have a problem with water milfoil which gets chopped up by the prop and will clog an internal strainer quickly. I added an external clam shell strainer with the slots facing aft and have not had any more problems.
Dec 19, 2006
5,832
Checking
I usually check my impeller 1 or 2 times per season here in Florida and sail
about 9 to 10 months a year is my season and usually go up north July & August
and some times Sept.
My H-36 came from the factory with the clam shell for the engine thru hull and
this was the first time I took a look inside the heat exchanger since boat was new in 2007 and thought it looked pretty good for sure.
I did rebuild the sea water pump about a year ago after it started leaking
and causing rust on the bracket and motor mount but have wire brushed it and repainted it
Nick
Dec 25, 2000
6,047
FWIW, our 1991 Hunter that we purchased in 2002 has a 4JH2-TE with 1,700 hours on the engine (647 hours when we took possession) and an Onan Genset with 450 hours (280 hours when we took possession). I replaced the original impeller on the Genset for the first time last year; it was due, but still working with all vanes intact and some cracking in the rubber material. I have yet to check the condition of or replace the main engine impeller. The PO had replaced it at least once. I suppose I'll replace it this coming season with the spare I have on board.
Jun 1, 2009
1,881
Hunter 49 toronto
Here's the problem...
Nick
I would normally pull the impeller every fall just to check it.
But, on the 49 it is a 2 hour job (minimum)
I'm sure that the 49 & 50aC owners are well aware of this issue.
As mentioned, I've come up with a solution to this problem which I'll be implementing in the Spring.
I am confident that my solution will permit impeller change in 15 minutes.
I'll have photos once it's finalized
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
I would also recommend, to control the zinc sacrificial, I decided to do a restore of the engine, and I also replaced the exhaust smoke but my water and very old. The impeller to change every year, if it does not turn sea water, before the engine warms up, it burns the muffler, because it is not soft dim the temperature of the exhaust smoke, and there is the danger of fire.
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
For this reason it would be better to put a temperature sensor on the muffler with an alarm, if the impeller is broken muffler burns before the engine warms up, but if part of an alarm, and more secure.
ELMAX
Jan 23, 2013
119
Hunter 35.5 Greece
Sorry for my English I think this is best to understand me.
The Council controls the anti corrosive zinc, i made the restoration of the engine, and I found the broken elbow mixing. The impeller to change every year, but it depends on how many hours the engine are made, if the impeller breaks, before damaging the engine burns the muffler, exhaust smoke is not cooled by sea water, the danger is a fire.
To find out if the impeller broke, i put a temperature sensor 85 degrees with a alarm on the muffler
Jan 4, 2006
7,610
WOW. You could eat lunch in that engine compartment! Nice Ralph
Who makes that flow switch?
Check the attached literature for flow switch specs. I believe it was about $70.00 when I bought it 8 years back.
As for the engine compartment ................ it has to be that clean. That's where I hide my lunch. Bloody crew would have it eaten within minutes if I left it lying around :eek:.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
Check the attached literature for flow switch specs. I believe it was about $70.00 when I bought it 8 years back. As for the engine compartment ................ it has to be that clean. That's where I hide my lunch. Bloody crew would have it eaten within minutes if I left it lying around :eek:.
Ralph, that is a brilliant idea, flow switch. I assume it is attached to some kind of alarm? I did not see any literature attached, I would be interested in doing this to my Yanmar 2gm. What kind of switch did you use?
Jan 4, 2006
7,610
No Attachments ? ? ? ? ...................
Had another enquiry complaining about not being able to see the .PDF attachment so maybe it's common problem. If you can't see the previous .PDF attachments, please see this site:
http://aqualarm.net/cooling-water-flow-c-2/
for Aquaflow products.
I see they've changed their technology from a magnetic slug on a guide rail being moved by the water flow against a spring ........... to a flow paddle which has a pivot point. This is the same as used in industrial flow detectors so if anything, it's better than what I have and it's $5.00 bloody dollars less than what I paid eight years ago :eek:.
The alarm can be wired through the same alarm as the low oil pressure alarm. I went a little more exotic and wired it through a different sounding alarm (physically the same alarm but on a different audible output) just so I can audibly check both alarms on engine startup. They both sound until I have both oil pressure and water flow.
With their expanded selection, for a Yanmar 2GM20F, you'd want the 10235 Cooling Water Flow Detector.
I hope this helps.
Sep 4, 2007
791
Hunter 33.5 Elbow, Saskatchwen, Can.
Ralph
I was able to read it with no problems. So I think all is good on your end.;)
HMT2
Mar 20, 2014
900
Had another enquiry complaining about not being able to see the .PDF attachment so maybe it's common problem. If you can't see the previous .PDF attachments, please see this site: http://aqualarm.net/cooling-water-flow-c-2/ for Aquaflow products. I see they've changed their technology from a magnetic slug on a guide rail being moved by the water flow against a spring ........... to a flow paddle which has a pivot point. This is the same as used in industrial flow detectors so if anything, it's better than what I have and it's $5.00 bloody dollars less than what I paid eight years ago :eek:. The alarm can be wired through the same alarm as the low oil pressure alarm. I went a little more exotic and wired it through a different sounding alarm (physically the same alarm but on a different audible output) just so I can audibly check both alarms on engine startup. They both sound until I have both oil pressure and water flow. With their expanded selection, for a Yanmar 2GM20F, you'd want the 10235 Cooling Water Flow Detector. I hope this helps.
Thank you Ralph. Mine is a straight 2gm with raw sea water cooling, there is no fresh water component. Would your recommendation be the same? Also, I am viewing this from an iPad and SBO app not a computer, perhaps that's why I can't see the attachment. I will check from my computer later and see.
Jun 1, 2009
1,881
Hunter 49 toronto
Here's what I did
I hope this helps.
Firstly, your choice of Aqualarm was spot on.
An excellent unit, and real cheap.
I put one on my genset, as well as engine.
But, I went a little more complex.
I wired both systems so that the engine & genset will automatically shut down if the intake sucks in a bag, etc.
There is a selector switch which bypasses the auto-shutdown, so it can be an audible alert only.
Here's why I did this:
On my Genset, hunter put in a water / gas separator.
You can't hear the genset running if you're in the cockpit.,,its that quiet.
So, that's the good news.
The bad news is that you just wont know if your water intake becomes blocked, as the water exhausts below waterline.
I've tested both genset & engine, and they shut down within 3 seconds of an intake blockage.
I leave the engine on bypass mode, where it's just an alarm sounding if a blockage occurs, but I do have the auto shutdown available if I want it enabled.
Jan 4, 2006
7,610
Flow Rate Requirement
Not familiar with how much sea water your engine would pass.
Best to try a test measuring the raw water pump intake from a bucket and compare to Aqualarm's required 3-4 gpm flow rate for their 10235 detector.
Jun 1, 2009
1,881
Hunter 49 toronto
It's adjustable
The sensor is adjustable.
All you need to do is as follows:
Run engine
Start adjusting sensor until alarm sounds
Then back off on the adjustment.
Super-easy.
The adjustment isn't super-critical. There is a very large variation in intake pressure between open flow & restricted.
Highly reccomend the Aqualarm sensor.
