Question for Hunter 23 owners
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
Looks like mine too - I can't measure it right now as it is in the yard and they lock the gates so we can't enter, and it's only open 2 days a week.
Dec 6, 2014
30
Hunter 23 Corpus Christi Marina
Looks exactly like mine! 1985 Hunter 23
I have a question on my hunter 23. I have water accumulate in the battery compartment. Every time it rains I can have more than 5 gallons.
It is in dry storage so it is strictly rain. I don't know how to post a new thread - if you could also tell me how that happens I would appreciate it!
Thank you
-na -NA Anywhere USA
suggest you post in the small boat section and on top, it has a "Post New Topic"
over the years folks change the location of the battery and need to know exactly where it is and photo. Do that and send it to davecondon@mindspring.com and I will help you.
Dec 6, 2014
30
suggest you post in the small boat section and on top, it has a "Post New Topic" over the years folks change the location of the battery and need to know exactly where it is and photo. Do that and send it to davecondon@mindspring.com and I will help you.
I have sent the information to your email address. If you do not see it please check your spam folder for txwallbed.
Thank you for your help.
Apr 27, 2010
1,279
If you mean the lazarette area under the cockpit. I would first check 1) the drain hose from the cockpit drain to the through-hull on the transom - if that is cracked, or one end is off the fitting, etc. you will fill that lazarette quickly 2) if the cover plate over the drain in the cockpit is covered with leaves or clogged, is the cockpit itself filling with water, and if so, does it get high enough to be above the access cover plate inside where the gas tank goes? While mine has a gasket or o-ring, it still leaks if that cockpit fills. Those are just two obvious checks.
