Have a 1990 Catalina 30. Will be replacing the rub rail vinyl in the spring. The old stuff was getting pretty deteriorated and brittle. While it's out I plan to check all of the rail screws/bolts. It appears that in some areas the rail is bolted through the hull (in the area where the shrouds are anchored and at the bow (I didn't check the stern area), and other areas it must be screwed.
Are these bolts and screws also the mechanical anchoring for the deck to the hull? It is typical that some of the rub rail would be through-bolted and some would be screwed?
Thanks in advance for any tips!!
