Odor from cockpit lazarette
Sep 1, 2014
47
Newport 28 Saint Augustine
Hello,
I thought my odor problem was coming only from beneath the V Berth. However, when i open the cockpit lazarette I get the same odor just as strong. I can see that the stuffing box drips every few seconds, leaving a small puddle and the salt water eventually makes its way to the bilge. Could this be an odor source?
Any suggestions/comments/remedies.
Advice is always appreciated.
ST
Sep 1, 2014
47
Doesn't smell like sewage per say, more of a chemical kind of smell
Sep 23, 2009
1,480
Chemical as in acid, sour or garlic or?
We have a faint garlic order that is strongest under the V berth but is detectable all the way back to the nav station locker. I replaced the vent lines. The hoses tested ok but I suspect the tank fittings are not sealed properly.
Are your ice box drain lines clean and clear? SHower sump could be another source.
Gunni
Mar 16, 2010
5,937
Hello, I thought my odor problem was coming only from beneath the V Berth. However, when i open the cockpit lazarette I get the same odor just as strong. I can see that the stuffing box drips every few seconds, leaving a small puddle and the salt water eventually makes its way to the bilge. Could this be an odor source? Any suggestions/comments/remedies. Advice is always appreciated. ST
You bet! Seawater is full of microbes and your bilge collects food like oil, grease, and Leprecaun bits. The microbes excrete hydrogen sulfide and stink the place up. Don't feed the wildlife. A clean bilge is an odor free bilge.
Sep 1, 2014
47
More of a sour smell. I replaced the head and most of the hoses. The vent line appears to be clear, but I will replace that along with the pump out hose.
Interesting that you ask about the ice box drain, because it has not been clear since we bought the boat 6 months ago. That hose leads to the lazarette. Could that really be a source of odor? Should I replace those hoses as well? Also, I never thought of the shower drain, which does run to the bilge. Should I pour something down it?
I appreciate your advice.
Sep 1, 2014
47
So how would you suggest I clean/treat this?
Thanks,ST
Gunni
Mar 16, 2010
5,937
There are specialty cleaning products labeled "bilge cleaner" that you can mix in a bucket of warm water and add to the bilge. But any number of detergents will work also. Let it soak and mop it out. A wet vac helps with extraction. Long term, clean bilges require regular maintenance, vacuum out the dirt, wipe up the oil & grease, and keep everything ship shape. Remember EVERYTHING that drops inside a boat, ends up in the bilge. Seawater and spills supply the medium and bacteria for bio reactionary stink down there.
Sep 23, 2009
1,480
I belive rariton makes an effective "odor eater" but can't remember the name. Hopefully our Head Mistress will chime in for you.
Hunter 29.5 Gloucester, VA
Njlarry may be referring to Raritan KO or Knock Out. Very effective in killing all kinds of oders
Shower drains pass hair, soap and exfoliated skin into the bilge if there isn't a sump. Basically a great medium for microbial growth. Yes, they can and do cause stink. If possible you should create a sump for the shower drain, which can be emptied - either by a pump or other means. It's not that big of a project.
Oxidizing agents in the bilge will mitigate the problem. Bleach, Oxiclean or a variety of other products help. As Leprecaun said "A clean bilge is an odor free bilge. "
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Shower drain into bilge is not good for many reasons as listed already. Definitely change that first
Mar 1, 2012
2,182
First thing I would do is check that ice box drain hose. Ice boxes are notorious fior having tiny food particles in them and a hose from there into the laz would be a PRIME suspect for odor, even more so than the shower drain. My ice chest has no drain- I use a small hand pump to empty into a bucket and dump over board.
I do agree on adding a sump to the shower, however personally I would never have a shower below anyway- mildew city. Mine is in the cockpit, or a wash cloth and tub in the main cabin. Ladies also.
Jan 6, 2010
1,519
Lep,
The guys here have given good advice pal.
Salt water with a drip stuffing box will add to odors when first opening the slats. Waste tank/head hoses leaching is also a contributor. Clogged or fresh water drains can grow mold that can have an odor also. Beware of some cleaners you may use to keep in compliance with local or state rules.
Here's a trick I use from time to time on my boat. I fill my bilge about 1/3 full. I use pool chlorine solution that I pour in the bilge. Depending on the size, I like to use a 15% mix. Then, I turn off the bilge pump and go sailing for the day, making sure I hit all points of sail, allowing the water to slosh about.
I never use chlorine on my boat, but some add this to their fresh water. I would never put up with a stinky chlorine smell in my water. I also add a small amount of pool chlorine to my fresh water, as it has aromatics & will not eat hoses like chlorine.
On the way back, I pump this out & do a fresh water 1/3 full in the bilge continuing the sloshing (pump off). I pump this out when close to the dock. It cleans & removes bilge smells quite alot. And, pool chlorine is cheap.
CR
Sep 1, 2014
47
Thanks All for the insight and suggestions.
Heading to the boat now armed with new knowledge.
I will report back
Sep 1, 2014
47
So NJ,
Even though Raritan KO is listed as a head/ holding tank product, would you still recommend it for the bilge?
Sep 23, 2009
1,480
Yes. Peggy Hall in her book Getting Rid of Boat Odors recommends putting it in a spray bottle for cleaning surfaces and allow to dry without rinsing.
Nov 8, 2010
11,386
Yes... But your boat is 25 feet long. Bigger boats with headroom and space can afford the luxury of a shower below. That plus pressure hot water is my simple defining characteristic of a 'big boat'.
