Impeller broken blades
Mar 23, 2013
132
Hunter 44DS Lake Macquarie
I just changed my impeller today and again discovered almost all of the blades were broken of, I got them all out of the oil cooler plus a few more as well as one large one in the intake area of the pump. It is only 10 months, 160hrs since I last changed and the last one was the same. Any ideas why I would be chewing up the impellers? In the manual it says to change every 1000hrs.
Nov 6, 2006
10,117
Broken vanes on the impeller are usually caused by a flow restriction which could be on the intake side or the discharge side of the system. Verify full flow area from the through hull fitting, through the strainer, all hose to the pump; no weed or clams or old collapsing hoses or plugged strainer. On the discharge side, plugging in oil or coolant heat exchanger or in the little fitting that hooks the hose to the exhaust elbow. If the pump itself is above the waterline, a small air leak in the discharge piping can do this as the pump has to re-prime every time it starts. running for even a few seconds with the intake seacock closed can do this too.. Happy Hunting.
Oct 14, 2005
2,191
Second Don's question...
as there has been reported impeller failures from one of the manufacturers over the past few years. With proper water flow, this could be the problem.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
I guess I will pull my for spring commissioning. Had not heard of the failures. I have a very short run to open water so I don't get many hours in a year. Thanks for the alert.
BarryL
May 21, 2004
1,074
Hey,
The only time something like that happened to me was when I used a Globe 'run dry' impeller. After one season all of the vanes had cracks near the root.
I went back to the black impellers and no problems since.
Barry
Feb 10, 2004
4,154
Hunter 40.5 Warwick, RI
I seem to remember that it was Globe impellers that were failing- a search on this site will turn up the correct info. 1000 hours is a lot. I have never seen a claim that any impeller will last that long. Unless there is a bearing failure that causes play in the impeller shaft, I generally get 200+ hours on my Jabsco impellers. I change mine about 200-250 hours or every other year which ever comes first.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Rich, Don: I have never heard of 1000 hrs either. I change my outboard ones every couple of years. Chief
Mar 23, 2013
132
It is in the Yanmar manual 1000hrs. I will definitely check min every service thou I am using Johnson impellers thanks for the info cheers
7,510
Alden 50 Sarasota, Florida
I have the same engine in our boat (4JH3b). If I am correct, the Hunter 44 has the same engine. After looking through the manual as well as the manual for other 4JH Yanmars, I can't find where it says that.
Can you point me to the specific reference?
Thanks
Nov 22, 2011
1,260
Ericson 26-2 San Pedro, CA
Thanks
Although this is for a different engine, I did find this in the Yanmar GM Series Operation Manual, p. 55: "Note: The seawater pump impeller must be replaced every 1000 hours or every four years, even if it is not damaged." The 1000 hr/4 yr. figure is repeated again on p. 58.
Seems like way too long to me! But that is what the Yanmar manuals says--to my surprise.
Feb 8, 2014
1,300
Columbia 36 Muskegon
I've also had terrible luck with Globe impellers. If there's any wear at all in the pump housing, the things won't seal well enough to pump at all. I've tried them on three different engines, never got one to work. Went back to the black rubber ones and no problems.
11,715
I winterize about 12 boats each year and also deal with water flow issues during the season. About 7 out of 10 boats I see have cracked or broken impeller blades within one to two years. Your impeller issues are not necessarily abnormal but it could mean a flow issue... Keep in mind that if you're in an area with high weed levels, Maine has lots of floating debris, partial flow restricting clogs can be quite common..
That said I have some owners who have gone 6+ years and the impellers still work but are really "limp" noodles. On most boats it takes about 5 minutes to change one but on some Yanmar's & Westerbeke's I curse the Japanese the entire time.....;););)
