I'd like to install a depth through hull transducer in my Hunter 216
Background: The 216 hull is composed of plastic outer, foam core and fiberglass inner.
An in-hull transducer will not work though the foam core based on tests and input from Hawkeye.
Hawkeye recommends the transducer be installed 6" forward of the centerboard but the floor steps up
and is quite thick to install the transducer.
Two questions I would appreciate input on:
Can I mount the transducer aft of the centerboard without significant turbulence interference?
What precautions do I need to take to seal the foam core to ensure that I do not cause
leaking between layers of the hull after drilling for the transducer?
Thanks for taking the time to read this and any insight you can provide
Top
