As you can see on the photos, the through hull nuts of my Beneteau 361 are on the hull and there’s a gap between the hole made to attach the through hull fittings and the hull liner (not sure if this is how is called; I mean the more “shining” fiberglass where the stickers are attached to). If any water gets into that gap do you think it will find its way to the bildge or will it stay stuck somewhere inside the hull? It’s not obvious when I look at them if there’s an exit somewhere (unlike to the liner where it leads to the lowest part of the bildge).
