Over the weekend I made a huge rookie mistake... When checking a chain plate on the port side I did not secure the mast and had it fall over the starboard side.
Thank God the mast did not bend! But did blow through one of the drill holes at the base of the mast. The plate at the step up got completely bet.
So I need to buy a new step up plate... the question is WHAT TO DO WITH THE MAST???
The mast did not bend but one of the holes at the bottom, for the through bolt, broke. Should I do a sleeve repair or should I cut the mast down an inch and re-drill??
Thank you for your input!
