My Irwin 28 is a centerboard model. I was just cleaning up under the floor panels and cabin storage areas because I am beginning to paint and "pretty up" some of the unsightly rough fiberglass down below. Sure enough crawling around these areas for the first time I came across a terrifying discovery.
I started inspecting my centerboard SS cable which appears to be healthy enough (my rigging guy just gave it a proper safety look over) but I am finding a lot of corrosion and big chunks of rust in the well under the centerboard seacock which he told me just to clean up and remove. It is definitely old (down there hasnt been cleaned up in decades), but I am very concerned. I have a pretty big access point in my port side storage down near the centerboard cable where I found a HUGE piece that is a good 4-5" wide and 7-8" long.
The question is, where did it come from, how did it get there, and is this level of corrosion a really bad sign? I have read about corrosion of keels, cast iron or other metal hardware, but nothing like this. As far as I know my keel is lead but I cannot get into that area and this definitely did not come from that. These chunks are sitting in the fiberglass well below the centerboard cable and updated seacock, and the big chunk was just sitting in a storage area I never used. I'm shocked I never noticed it before until now. It was very well hidden from view but now that I found it I am very concerned.
The boat hull and body is absolutely clean and practically brand new on every other level. So I am flabbergasted more then anything by this odd discovery. Any thoughts or comments are appreciated.
