Bow Thruster
Nov 27, 2014
12
Beneteau 423 Portsmouth
I am in the process of buying a 423 and want a bow thruster fitted. The dealer is recommending "quick" thrusters and says Beneteau now fit these as standard. Does anyone know this brand and could share knowledge?
Thanks
Keith
May 25, 2004
448
Catalina 400 mkII Harbor
not sure about that make, but when my neighbor wanted to add a thruster (lewmar) on his 423 the yard wanted 13,000.00. so his thought process was for him to try it him self and if he screwed up it wouldnt cost much more for the yard to finish the job and repair any damage he made. the result was a perfect installation (by him) with a price a little bit more than the cost of the thruster and his time. way under the 100 hours or so that the yard quoted.
Nov 27, 2014
12
Thanks. The yard is quoting a good price but I have never heard of the Quick brand before. They look good from the website but haven't come across them before. Is the price too good I am wondering !
Keith
Jul 12, 2012
73
Beneteau 41 Kemah
I had never heard of them before I bought a B41. I've had it two years now. The thruster gets a lot of usage and never had a lick of trouble yet. Same goes for the Quick Windlass that also came factory installed.
Sep 8, 2013
71
Beneteau Oceanis 45 Rock Hall, MD
My 2013 OC45 was built in Marion SC and has a Max Power Bow Thruster(French/Italian?). The Windlass is Quick.
Nov 27, 2014
12
Bill,
No it's a white one and located in Europe ! By the way the owner is saying that the bow thruster is really not necessary and just slows the boat down in light airs. Anyone have a view on that ?
Keith
Nov 24, 2012
586
Bill, No it's a white one and located in Europe ! By the way the owner is saying that the bow thruster is really not necessary and just slows the boat down in light airs. Anyone have a view on that ? Keith
I have one on my 423 and I would question that statement. The typical install has a slight flair on the forward side of the tunnel which would reduce drag. FYI our 423 is very fast in anything above 8-10 Kts of wind. Below that it is slower but not because of the thruster - it's the 24000 lbs.
Sep 8, 2013
71
As Captn TJ says the tunnel should have a taper front and aft to reduce drag. Download an Installation Manual and it will outline the taper ratio.
Myself I would not be without a thruster, life is way too short. I also doubt very much that it creates a noticeable drag.
Nov 27, 2014
12
Thanks to everyone for their advice. I think on balance I will get the boat initially without the thruster , try it for a season and get one fitted once I get used to handling the boat. As an aside and something I had not considered , my wife (being very practical) has questioned the wisdom of putting a darn great hole right through the bow that might let water in !! It's a thought I guess....
Sep 8, 2013
71
Since you are buying the boat used it's not really a big issue. You can as you say decide later, and it might help give you some time to research it. The electrical and controls could be installed anytime, prep a tube for the thruster, then punch the hole when it goes hard again.
As for the big hole? It's a pretty popular big hole, and probably of less concern than say a failed hose or a seacock rotting off.
Jul 12, 2012
73
Beneteau 41 Kemah
One of the best investments I've ever made on a boat. My cocaptain loves to park it now. Before, I couldn't get her to touch the wheel. Going to the pumpout station is a hoot. Get out of the way, she's acoming through. Woohoo. Also comes in handy because my marina has really borrow aisles.
