hello all, i am looking for some advice as to how best repair my problem.
I have a hunter 23.5 When i bought it a few years ago, the original owner had broke the original mast and replace it with a similar but not exactly the same size extrusion from dwyer mast. Due to the shape being slightly different a different hing plate assembly was needed so it will look different than stock.
He had used the original spreaders but put them on dwyer mounts which didnt hold them tight and i assume this is why the mast base became weak. this year while lowering the mast the base broke free from the mount and cause the "slot" like defects where the base mount was affixed to the extrusion. I have a new base to put into the extrusion base but am looking for advise on how best to handle the fact that there are now gaps where the screws pulled thru and stripped "slots" into the aluminum of the extrusion.
I have gotten several bits of advise but seek other opinions.
1) Heliarc weld the base plate to the mast as is. I was also advised against this by some who say that the welding of aluminum may further weaken it from the heat
2) cut the mast short by the approx 1 cm and see if i have enough play left to tighten the rigging and if not ad a spacer block under the base (between the base plate and the top of the hinge step of block aluminum)
wondering what advise or experience might be out there....
pictures are of the damage; the base plate; the hinge plate, and how they go together
