We bought our boat in April 2014 and I have never reefed it yet. I have read how to reef the mainsail, but I am not sure which method is best.
I have a track and pulley on the end of my boom like the one in the first attached photo. There is a line attached to the last reefing point and is ran down through the pulley and can be cleated when I need it. There is also a line attached to the reefing point on the mainsail close to the mast. There is also a reefing hook and a cleat where it can be cleated.
I also have other reefing points in the middle section of the mainsail that do not currently have a line attached, but I could use these as well. I have read how to reef it using All the reefing points and also a single line method.
My question is should I use the single line method ( and if yes which of the 2 methods - see second and third attachments please)or use All the reefing points? Mine currently is not setup where I can reef the mainsail from the cockpit, but it appears that I could add a couple pulleys/blocks and then reef it from the cockpit. But then It would only be using the forward and aft reefing points. What is best?
Thanks Mike
Thanks Mike
