IMHO they all suck (pun not intended)....
The companies have cheapened them so much I see 1-5 years as average. I heve tried and installed them all SHURflo, Johnson, Jabsco etc...
If you want a macerator to last a bit longer install it slightly higher than the holding tank so effluent self drains out of the pump head. Yes the impeller runs dry for a short time but the acids don't kill the pump as quickly. The impellers generally survive it is the head that starts leaking effluent or bolts that corrode and literally fall out. If effluent sits in the pump head continually expect a couple of years at best before you find a bolt in the bilge or a $hitty smell in your boat... I can't even begin to count the number of macerator pumps I replace...
Diaphraghm waste pumps such as the Whale Gulper's are more reliable but don't lend well to drop in replacements for a macerators because, well, they don't macerate. These pumps use 1.5" inlet and 1.5" outlet where a macerator is a 1.5" inlet and 1" outlet. Kind of tough to
drop-in if your boat has a 1" seacock..
Raritan just introduced a new macerator pump, due out in December, but I have not been able to get important construction details about it to determine if it may be any more reliable than the others. Raritan's older macerators were simply re-branded Sure-Flo...
Unfortunately these companies just
copy each others
crappy products. It would be like everyo auto company copying the Yugo and putting a Cadillac brand badge on it...
Hopefully Raritan did not try and copy products that
suck, for their new macerator, and actually did some R&D...
