Hunter 270 winch info required
jpaull
Dec 28, 2011
9
hunter 270 Adelaide
Hi. I have a Hunter 270 and would like to change my winches to self tailing. However when I looked at how the existing winches are attached I found that it has no backplate. If I increase the size of the winches from lewmar 6 to a self tailing winch do I need to instal backing plates. Can anyone please advise. Also I am in Australia and it is difficult to find hunter parts so will probably just buy whatever I can find here in Adelaide. Thanks. John
Nov 8, 2010
11,386
For any winch on any boat large fender washers will be fine. No true backing plate needed. The the load on a winch is in shear, so there is very little lifting (tension) pressure on the winch pulling on the bolts or plates.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I installed ST Andersen winches on my H260 (same boat as yours but water ballast). There is an aluminum plate glassed into the deck where the winch is installed, should be no problem upgrading your winches. I have a photo album in my profile of some H260 mods I did on my boat, might give you some ideas.
Good luck, Bob
jpaull
Dec 28, 2011
9
hunter 270 Adelaide
Hi Bob and JackDaw. Thanks for the quick reply. I am off to buy new winches - woo hoo.
jpaull
Dec 28, 2011
9
hunter 270 Adelaide
Bob I see you are on line. Another question. Like your photo of your winch. Do you have more photos to share. I am pretty new at sailing and especially modifications and maintenance. Any ideas would be much appreciated.
May 16, 2007
1,509
Have a look here, http://forums.sbo.sailboatowners.com/album.php?albumid=1031
If you have any questions on my mods or the 260/270 feel free to contact me by PM using this site.
Fair winds, Bob
jpaull
Dec 28, 2011
9
hunter 270 Adelaide
Fair winds, Bob
Hi Bob
Thanks. Your modifications look great! I am sure to have questions and thank you and will PM you when I have more questions. In the meantime if ever you come to Adelaide, South Australia please let me know. Regards. John
