sprocket rotary drive
Dec 14, 2011
316
Navicula 430 Hunter Toronto
I have contacted ....Applied....for a quote on my sprockets for my type 2 rotary drive,
as per the chart I need a 15 tooth and a 57 tooth sprocket with a three eighth pitch..........the 15 tooth is no problem along with the chain.......but the 57 tooth is a special order and its 450 bucks..........(the 15 tooth is 70 bucks).....
am I looking in the right spot....
is this normal....
please adise
thanks
Dec 29, 2009
149
Hunter 380 Little Creek, Virginia Beach, VA
Check with Marlowe-Hunter. When i asked them about the same set up for my 380 - which would use a type 1 drive, they referred me to Grainger for the sprockets. I didnpt find a 57 tooth sprocket at grainger, but there may be other sources, and Marlow-Hunter might know them.
-charlie
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
You might want to give Tsubaki a call.
Head Office & Manufacturing Plant
1630 Drew Road
Mississauga, Ontario L5S 1J6
Tel: (905) 676-0400
(800) 263-7088
After Hours Number: (905) 601-3043
Fax: (905) 676-0904
Email: info@tsubaki.ca
Distributers are:
BDI CANADA INC.
119 SPADINA AVE
STATION B, BOX #37
Toronto, ON
M5T 2T2
Tel: (905) 238-3392Fax: 9052380102
TORONTO GEAR WORKS LIMITED
39 BERTRAND AVENUET
Toronto, ON
M1L 2P3
Tel: (416) 751-2121Fax: (416) 751-7023
MOTION IND - ON
12200 QUEENS QUAY EASTUNIT #2 & #3
Toronto, ON
M5A 4K9
Tel: (416) 465-8250Fax: 4164659866
C.B.S. EQUIPMENT LIMITED
777 UNIT B, THE QUEENSWAY
Toronto, ON
M8Z 1N4
Tel: (416) 252-2555Fax: 4162525389
Renold Canada also makes sprockets.
Their Catalog shows a 57 tooth 3/8"pitch (#35) cast iron sprocket as a standard size.
Brantford (Ontario)
Tel + 1 519 756 6118
Fax + 1 519 756 1767
Last but not least Amazon.com
http://www.amazon.com/Ametric®-ANSI-35-1-Steel-Sprocket/dp/B00I7589UI
Don't know if that helps?
Good Luck
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
find a go kart racing supplier and get a axle drive sprocket ...we used theses all the time when i was racing WKA karts...they come 2 piece for quick change and can be adapted to your old hub
Jun 1, 2009
1,852
Hunter 49 toronto
Ok,,,,
is this normal....
please adise
thanks
Couple of things.
I am very familiar with the rotary drive setup in the 40.5 and 43.
The gear ratios are guides, but close matches will also work.
Here is why.
The rotary drives are typically intended to drive the quadrant directly, either through a chain spliced into the stainless quadrant wire, or an independent quadrant on the rudder shaft.
In both cases, the motor is somewhat heavily stressed.
On the hunter install, you are driving a gear on the steering wheel hub.
The wheel is already highly geared to the rudder through the radial drive.
Proof.... You can steer you boat wheel with 1 finger.
Yes,,,,, I know that there is more torque on the wheel rim than at the center of the shaft, but if you hold the wheel at the spoke center, you can still turn the rudder.
Now, what might be making things expensive is the type of hub you are choosing. I would consider looking at a Fenner Transtorque coupling, which will adapt gear flanges, and do a much better job of mounting gears on shafts.
Lastly, you MUST have stainless chain.
I bought a bunch of it for my install, as there is a minimum order.
You can pm me.
I would also get the gears chrome plated. Way Cheaper than stainless.
