I removed my hand rails, hatchboard rails and gas tank rail today with the intention of sanding and refinishing over the winter.
As you can see, the port rail is fatally wounded.., well, if they were in better shape I might try a repair but they are all pretty rough shape.
Not being a fan of woodworking or maintenance, I`m thinking about replacing them all with plastique.
I`m not familiar with it, I`m not a woodworker so I have questions.
I was surprised that the bolt hole spacing on the rails was not consistent. from stern going forward spacing is about 9", 10.25", 9.25 ". These are through bolted, I removed the plastic caps and nuts in the cabin headliner and pried them up.
If the replacements are not predrilled, (It`s unlikely they are I figure, certainly won`t match my bolt holes) I reckon I would just position them over the existing holes and run a tiny drill bit up through from the inside through the bolt holes to mark the undersides. I would then be inclined to just run wood or sheetmetal screws in from the bottom and not through bolt them this time. Yes/No/ maybe?
