Are horizontal lineson mainsail from the luff normal?
Nov 13, 2013
17
Catalina 22 MKII Marina Del Rey
This may be a dumb question but I'm still really new to this. But are the diagonal folds show in the picture, that start at the luff normal? I don't know if "folds" is the right word. I'm referring to the creases in the mainsail fabric all the way down the luff. Is this a sign of improper halyard tension when I initially raised the sail? Again I'm new to sailing. Catalina 22 with no Cunningham, thanks in advance. image-1667791479.jpg
Apex
Jun 19, 2013
1,223
C&C 30 Elk Rapids
often referred to as scallops, halyard tension as I undertand should be:
light wind, leave the scallops JUST in.
high wind, tighten halyard or cunningham to remove.
-na -NA Anywhere USA
Two possibilities of sail too big/luff too long and main halyard not pulled tight enough could be the issues. Not knowing what the age of the sail is or what it has been thru, the third possibility is the bolt rope encapsulated in the luff may have stretched and the only way to fix is to send off to a sail loft for repairs unless you know how to fix and have the machinery to fix it with.
Or...drop the gooseneck down a bit. Issue solved, sail is not too big.
Jun 11, 2004
1,918
Oday 31 Redondo Beach
My old Catalina 22 had a down haul on the boom so you could pull the gooseneck down and get rid of some of those. That was in the early 70's though, hull #446. Don't know what they might have now. That was a good boat. It's amazing they went on to make 15,000 more of them.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
+1 on Stu and Richard. Catalina 22 booms crawl up the mast unless you anchor the gooseneck down with a line. Also make sure your topping lift is fully off when mainsail is at full hoist.
Ray
