Outboard Sheeting
Oct 21, 2014
5
Hunter 460 Midland
My Hunter has the jib sheeting points on the inside cabin top roof. This is good sheeting area for pointing high into the wind. If I want to go off the wind I need an outside sheeting point, something on the rail. Has anyone developed a good solution for outboard sheeting?
Feb 6, 2010
154
hunter passage456 kemah
Outboard sheeting for passage 456
Thanks for the detailed information! I will just have to figure out how to apply it to my boat!
Our 2002 boat is basically the same as yours , it had 3 oem pads built in to the toe rail, one just forward of the outboard shroud, one midships, and one toward the stern, one had a pad eye installed at the factory, I installed pad eyes on the other two, the use snatch locks to sheet the headsails more outboard. Our boat is center cockpit, but it should not matter.
Oct 21, 2014
5
Hunter 460 Midland
Thank you for your reply!
Yes, I have the same pads although mine didn't seem to line up where I would have chosen to do outboard sheeting. However, what you say makes sense. Did you have any issues accessing the pads to add the pad eyes?
