Have a 93 Hunter 33.5, 54ft mast, 2 VHF radios, one at the nav station ( original equipment) and a new radio at the wheel. Both go thru a manual antenna switch that is in good shape, inside and little use. Antenna is a whip at the mast top.
Today I could receive on both but not transmit with either radio. Dont think it is the radio or the switch, thinking I may need a meter on the antenna wire at the mast top and also at the radios ( done 1st of course),the wire may have gone bad. Looked at the wire as in the boat as far as I could,looked ok.
Anybody ever had a similar problem ?
