Well, I spent yesterday redoing my alignment job I did last weekend. As noted in a previous post, I found out the rear motor mounts ran out of down adjustment. Yesterday I raised the shaft log up and ground down a little of the mounting surface on the boat so the shaft log is angled a bit more. I found a great tip on taping hardwood dowels around the prop shaft at the area that will be inside to shaft log to help center it. I used my angle finder to take readings on the motor coupling, shaft log, shaft and strut. All is good except the strut (see pic). I am holding the strut at the approx. position it will need to be in. It is centered to the skeg and shaft and rotates freely (I temporarily bolted the strut up yesterday). Anyway, there is quite a gap. Just looking for suggestions on filling it. Use washers and use Sikaflex to fill in the gaps? Build up with West System and fair it?. This is a cast bronze strut so bending the tangs is not a good option.
