haul out today and aft end of keel supporting boat, you can pass your hand under the front of keel should I be concerned?
boat sits high in the bow ,I mentioned this to the crew and only comment I got was ,water will drain better.....
this is a fin keel and the trailing edge is thin, and the weight of boat is resting on the trailing edge...
should I make a fuss and have them reposition it , or ?
your thoughts please
